    M5.Lcd.drawJpg in python
    5 Posts 4 Posters 9.7k Views 1 Watching
      Powersoft
      Is there an equivalent version of "M5.Lcd.drawJpg" in python on the M5Stack?
        tehnolog
        lcd.image(100, 100, file="res/default.jpg", scale=0, type=lcd.JPG)
          image0 = M5Img(107, 65, "res/default.jpg", True)
            mb @ajb2k3
            Hi @ajb2k3, is M5Img still the preferred way to display an image on the Core2?
            Somehow it doesn't work for me, neither from flash nor from micro SD card.
            >>> from m5stack import *
                from m5stack_ui import *
                from uiflow import *
                image0 = M5Img(0, 0, "/flash/images/sled240.jpg", True)
              File "<stdin>", line 4, in <module>
              File "m5stack_ui.py", line 493, in __init__
            TypeError: 'int' object isn't iterable
            I can use lcd.image(), but that crashes for pictures from the mico SD card (link).
              mb
              Now I found working code for UIFlow 1.7.2, but this only supports PNGs:
              screen = M5Screen()
              screen.clean_screen()
              image0 = M5Img("/sd/images/sled150.png", x=0, y=0, parent=None)
