M5.Lcd.drawJpg in python
Is there an equivalent version of "M5.Lcd.drawJpg" in python on the M5Stack?
lcd.image(100, 100, file="res/default.jpg", scale=0, type=lcd.JPG)
image0 = M5Img(107, 65, "res/default.jpg", True) -
Hi @ajb2k3, is M5Img still the preferred way to display an image on the Core2?
Somehow it doesn't work for me, neither from flash nor from micro SD card.
>>> from m5stack import * from m5stack_ui import * from uiflow import * image0 = M5Img(0, 0, "/flash/images/sled240.jpg", True) Traceback (most recent call last): File "<stdin>", line 4, in <module> File "m5stack_ui.py", line 493, in __init__ TypeError: 'int' object isn't iterableI can use lcd.image(), but that crashes for pictures from the mico SD card (link).
Now I found working code for UIFlow 1.7.2, but this only supports PNGs:
from m5stack import * from m5stack_ui import * screen = M5Screen() screen.clean_screen() screen.set_screen_bg_color(0xFFFFFF) image0 = M5Img("/sd/images/sled150.png", x=0, y=0, parent=None)
