    [Core2] M5Timer-Lib // How to use "numTimer" in e.g. "setInterval()"
    core2m5timernumtimer
    2 Posts 2 Posters 6.0k Views
    • W Offline
      wa-berlin
      I want to use the M5Timer Library with Core2.
      In <M5Timer.h> there are functions having a <numTimer> argument and those without.
      Questions:
      How can I use
      with a certain timer?
      I am simply missing the argument "numTimer" in the function.
      A working example for Core2 would be helpful.
      Thank you in advance.
        Hello @wa-berlin
        you can't. Functions w/o numTimer argument will return the internal number assigned to a specific timer. You don't have direct control about which timer gets which number, but you can keep a record of the number assigned to a given timer to further manipulate it.
        Below is an example with 2 timers (A and B). Timer A counts up ever 2 seconds, whereas timer B counts up every second and stops at 10.
        With button A you can enable and disable timer A.
        With button B you can restart timer B once it has stopped.
        #include <M5Core2.h>
        #include <utility/M5Timer.h>
        M5Timer M5T;
        int mytimerA = -1;
        int mytimerB = -1;
        int mycountA = 0;
        int mycountB = 0;
        void myTimerACB(void)
          mycountA++;
        void myTimerBCB(void)
          mycountB++;
        void setup()
          M5.Lcd.setTextSize(3);
          mytimerA = M5T.setInterval(2000, myTimerACB);
          mytimerB = M5T.setTimer(1000, myTimerBCB, 10);
        void loop()
          M5.update();
          M5T.run();
          if(M5.BtnA.wasPressed() == true)
            if(M5T.isEnabled(mytimerA) == true)
              M5T.disable(mytimerA);
            else
              M5T.enable(mytimerA);
          if(M5.BtnB.wasPressed() == true)
            if(M5T.isEnabled(mytimerB) == false)
              M5T.deleteTimer(mytimerB);
              mycountB = 0;
          M5.Lcd.setCursor(0, 0);
          M5.Lcd.printf("Timer A: %s\n", M5T.isEnabled(mytimerA) ? "enabled " : "disabled");
          M5.Lcd.printf("Timer A: %04d", mycountA);
          M5.Lcd.setCursor(0, 100);
          M5.Lcd.printf("Timer B: %s\n", M5T.isEnabled(mytimerB) ? "enabled " : "disabled");
          M5.Lcd.printf("Timer B: %04d", mycountB);
        Good luck!
