    M5StickV won't turn back on
    Scheduled Pinned Locked Moved M5Stick V
    3 Posts 2 Posters 7.4k Views
    • B Offline
      brunovianna
      I turned it off using the power button, now it won't start again even with USB plugged, after pressing the power button for more than 2 seconds.
      Is it possible that I shortcircuited it by plugging USB cable into grove slot?
      • B Offline
        brunovianna @brunovianna
        @brunovianna apperently, you need to let the battery charge for a while...
        • B Offline
          bigpotatobrain
          so i asume its fixed now then?
          i also ran in to the problem a while ago turned out if you activate the burner it works to
