UIFlow 1.7.8
Ver 1.7.8 time: 2021.06.04
v1.7.8
new features
- UNIT:
- UNIT NB-IoT support.
- UNIT OLED support.
- IoT Cloud:
- Ali IoT support.
- On-board IR(NEC):
- StickC/StickC-Plus/ATOM support.
Bug fix:
- Core2 microphone record bug fix.
- Core2 speaker play wav audio bug fix.
After the release of UIFlow 1.7.8. I can't upload my custom blocks anymore.
With 1.7.7. it worked great. Please fix it! -
Hi. we already fixed it.
Funny bug, while plaing with Atom Lite and Oled when GUI is hidden all elements with i would like to add or move is going to be delated ...
https://ibb.co/ryfQjdb
@mati thank you feedback. we will fix as soon as possible.
@m5stack where can I download 1.7.8 for desktop?
I can use 1.7.8 on cloud and it contains functions I need (e.g. UnitV2) but, even o m5stack downloads - I can only get v1.7.4.Also, any chance of adding the version number to the file name?
THanks
Ian -
What about grabbing the content of a fully-loaded webpage? Where is the javascript functionality? This functionality needs to be implemented into UIFLOW for all M5STICK'S as it otherwise lacks ability for the hardware that is there, Please don't turn into apple.
@ianlyonthomas The update speed of the desktop version will be slower than the online version. If you want to use the latest features, it is recommended that you use the online version.
@m5stack said in UIFlow 1.7.8:
- On-board IR(NEC):
Is there any documentation/example for using the IR Remote Unit to receive and send in the recently added NEC IR mode.
I realise that that that it said for the "On-Board" IR on the Stick C Plus but wondered what it means by "Recommended download to the device for use NEC mode" - I can't find any help anywhere unless I use Python and the existence of the "IR Receive Data" implies that I can receive NEC codes using the IR Unit with a Stick C-Plus
Many thanks
- On-board IR(NEC):
I can confirm that M5StickC has no receive, only IR Infrared transmit
A workaround, if you have a line follower (HW-006) or similar you can use a Grove2Dupont cable to connect the sensor to the M5StickC but (V. IMPORTANT!!!) swap the 5V input to the sensor with jumper cable to the 3V3 of the hat connector on the stick. This will allow a quick test of the receive block associated with the M5Stack IR module block in UIFlow.
What I discovered is that the standard transmit block (under Hardware > IR). Only accepts one byte for data and one byte for address. According to the NEC standard (not extended) the first 8 bits are the address and 17-24 bits are the command (NB 'data' is a bit of a loose term, it would be better as 'command' in the UIFlow block, datagram or 'data' to mean the assembled code).
Next gotcha, the bits need to be reversed to use with external equipment, note reversed not inversed. Tool for this: https://www.browserling.com/tools/reverse-binary
And this tool to swap between binary and hex
https://www.rapidtables.com/convert/number/binary-to-hex.htmlAn example:
The code I wanted to send: 0x00F7B04F --> the first byte is not the inverse binary of the second, so it is NEC extended and, so far as I can tell, is unsupported in UIFlow - ideally this needs fixed or second block added!2nd attempt to use IR to turn on/off LG TV with book code: 0x20DF10EF
Logically, I took 20 to be the address and 10 to be the command ('data' in UIFlow block). Sadly, it wasn't. To make this work the addr and data values need to be reversed therefore 20 --> 0x04 and 10 --> 0x08.Hence, I made the UIFlow block: IR(NEC) send addr 0x04 data 0x08 (alt Python ir.tx(0x04, 0x08)). Triggered from button on Atom this worked on my LG tvs.
Interestingly, send and receive between Atom and M5StickC didn't reverse the bits. So, I would assume the same would happen if using the receive to scan from a remote.
A couple of other examples:
https://flow.m5stack.com/?examples=ir_nec_sender_demo
https://flow.m5stack.com/?examples=ir_nec_receiver_demoSome other useful references:
https://github.com/esikora/ESP32App_Led_IR/blob/PlatformIO/src/ESP32App_Led_IR.cpp
https://exploreembedded.com/wiki/NEC_IR_Remote_Control_Interface_with_8051
https://www.sbprojects.net/knowledge/ir/nec.php
https://qiita.com/poruruba/items/34220a4dd6aaf48392aa
https://docs.m5stack.com/en/unit/ir
https://shop.m5stack.com/products/stick-c
