    UIFlow 1.8.0
    31 Posts 11 Posters 92.2k Views 2 Watching
    • OyczEO Offline
      OyczE
      Bug#2 Remote+ missing variable in Button
      • U Offline
        UKTechguy @John7
        @john7 said in UIFlow 1.8.0:
        "Blockly.RemotePlus":[{"createTime":1625241945254,"name":"M5Remote","dragAndDrop":false,"resizable":false,"color":"#fff","bgColor":"#0080FF","type":"title","id":"__title"}],
        Thanks for the tip. That sorted it for me. Shame M5STack don't perform better quality control.
          Hello @Mati
          thank you very much for letting us know. I've just retried REMOTE+ myself and this time it worked. Either something went wrong the first time or maybe M5Stack fixed something already.
          • OyczEO Offline
            OyczE
            @m5stack just a one small suggestion, maybe development sprint or deployment should be done at monday then we are not losing weekend to be frustration.
            ajb2k3A 1 Reply Last reply Reply Quote 3
              ajb2k3 @OyczE
              @mati
              @mati said in UIFlow 1.8.0:
              This I wholeheartedly agree with!
                anvalin
                • m5stackM Online
                  m5stack @John7
                  @john7 thank you feedback. we already fixed the issues. pls try again.
                  • m5stackM Online
                    m5stack @OyczE
                    @mati actually that just a button. this function just like a callback, each time you press it, the function exec one time. so it can without the variable.
                      Hello @m5stack
                      thank you for letting us know. I appreciate it.
                      And yes, I can confirm that I can load previously saved m5f files into UIFlow 1.8.0 again.
                      • OyczEO Offline
                        OyczE
                        Hello @m5stack
                        #1
                        looks like new error popup in combination of Atom Lite and OLED 1.3'' module not only Env2 make error as well.
                        Simple remove 'from m5stack_ui import *' fix the problem
                        #2
                        Plus AtomLora DUT error ..
                        File "flow/m5cloud.py", line 82, in _exec_fun
                        File "<string>", line 3, in <module>
                        ImportError: no module named 'base.DTU_LoRAWAN'
                        #3
                        LoraWan868 + Core2
                        'module' object has no attribute 'LORAWAN'
                        Do we have any LoraWan support in 1.8.0 ?!
                        Regards
                        Mati
                          deathvedar
                          We tried to run the LoRaWAN 868 Unit with absolut no luck.
                          If i select it in the UIFlow event the frequency mask is empty while the mask of a 433 unit is pre filled.
                          please, please fix this ASAP!
                          • OyczEO Offline
                            OyczE
                            @m5stack could we get reply about uiflow support for lorawan ?
                            • m5stackM Online
                              m5stack @OyczE
                              @mati you could try 0001 for the mask code
                              • m5stackM Online
                                m5stack @OyczE
                                @mati did you open more than two UIFlow web pages? if you open two pages in the same browser and use different hardware. that would have some conflict. so I think you just need to open a new browser. it will work fine.
                                OyczEO 2 Replies Last reply Reply Quote 0
                                • OyczEO Offline
                                  OyczE @m5stack
                                  @m5stack indeed it was two tabs !
                                  Let me check this, thx for a hint.
                                    tnkmasayuki
                                    I can't stop the sound.
                                    UIFlow1.8.0 + M5StickC Plus
                                      stefanj9
                                      Wher can I find version 1.8.0?
                                      • OyczEO Offline
                                        OyczE @stefanj9
                                        • OyczEO Offline
                                          OyczE @m5stack
                                          @m5stack hmm no luck one tab and still error
                                          but ... its just bug me so after listing all modules on AtomDUT its turn on you have made a typo in the from base.DTU_LoRAWAN should be base/DTU_LoRaWAN
                                          from base.DTU_LoRAWAN import DTU_LoRAWAN
                                          into
                                          from base.DTU_LoRaWAN import DTU_LoRaWAN
                                            plusulli
                                            In the Remote+ documentation for the slider it says "click the gear button on the block to add a variable before use" But there is no gear button.
