    UIFlow 1.8.1
    21 Posts 11 Posters 64.8k Views 2 Watching
    • m5stackM Online
      m5stack @plusulli
      @plusulli thank you feedback. it already fixed.
        plusulli @m5stack
        @m5stack said in UIFlow 1.8.1:
        Great that's how it has to be
          Hello @m5stack
          on M5Core2 (running UIFlow fw 1.8.1), with the boot menu option set to false, still shows the splash screen and the menu screen before actually starting the previously downloaded .py code.
          Could you please have a look?
          P.S. Reported here.
          • m5stackM Online
            m5stack @felmue
            @felmue you could change the mode option to the WiFi mode in the boot menu. and then reboot the device it will starting the UIFlow program mode.
              favnec5 @m5stack
              @m5stack
              Hello. Sorry but i don't understand. Wifi mode will display wifi ssid for wifi connection. The problem is that, in the app mode, "boot menu : false" in the M5Burner software don't hide the splash screen and the boot menu at core2 startup.
              Thanks.
              Thomas
              Thomas
                Hello @m5stack
                I am sorry, but there is no WiFi mode for M5Core2 - or am I missing something?
                I only see Internet Mode, USB Mode and App Mode.
                • m5stackM Online
                  m5stack @felmue
                  @felmue actually the WIFI mode is the Internet Mode. they are same
                    Hello @m5stack
                    thank you for the clarification. However when I use Internet Mode my M5Core2 shows the UIFlow flash screen, the UIFlow menu and then connects to the UIFlow Cloud. (Which btw is what I would expect it to do in Internet Mode.)
                    As stated before, also by favnec5, is that with Start Mode set to App Mode and Boot Menu set to False M5Core2 still shows the UIFlow flash screen and the UIFlow menu before starting the previously downloaded .py code.
                    Please fix or advise.
                    P.S. the issue only is with M5Core2 - it works properly on M5Stack devices.
                      Still no way to read and write to SD cards in UIFLow on the M5Paper?
                        retro
                        Hi! When will the UIFlow Desktop be updated to version 1.8.1?
                        • NN708N Offline
                          NN708
                          Hello @m5stack,
                          I want to modify the MicroPython code for PaHUB, but I found that the repository on GitHub (https://github.com/m5stack/UIFlow-Code) is outdated. Could you update this repository to the newest version?
                            Can't connect NCIR to PaHub in UIFlow
                            • IAMLIUBOI Offline
                              IAMLIUBO @ajb2k3
                              @ajb2k3 said in UIFlow 1.8.1:
                              Thanks feedback, we will update this issue.
                                tnkmasayuki
                                UIFlow1.8.1
                                The MAC address of EspNow is the MAC address of SoftAP.
                                The Mac address of EspNow reception is the MAC address of Station mode.
                                They are different numbers and should be unified to Station mode.
                                  ajb2k3 @tnkmasayuki
                                  @tnkmasayuki AP and Station need different mac address in order to communicate in different modes.
                                    tnkmasayuki @ajb2k3
                                    ESP-NOW uses only the MAC address of the station.
                                    However, SoftAP is displayed as your own MAC address of ESP-NOW.
                                    I want the MAC address of the station to be displayed.
                                    The problem is that the received MAC address is different from your own MAC address.
