    UIFlow 1.8.2
    19 Posts 10 Posters 37.2k Views 3 Watching
    • liemphL Offline
      liemph @m5stack
      @m5stack Does it support BaseX? I could not run the same UIFlow script (previously worked) to drive the BaseX.
      • m5stackM Online
        m5stack @liemph
        @liemph fixed.
        • liemphL Offline
          liemph @m5stack
          @m5stack Thank you very much. I will try.
            capacious
            Where can the desktop IDE for this version be gotten from?
            I need the Thermal Unit on a Fire but uploading it via the internet connection and the online IDE is very instable.
            I'm only able to download UIFlow-Desktop-IDE version 1.0.17 that contains UiFlow version 1.7.5.
            Creating the file online and then trying to upload it via USB via the lower versioned desktop IDE doesn't work.
              capacious
              Another thing I notice is that in version 1.8.2 when trying to load the THERMAL demo it 'hangs' and doesn't load anything.
              </> Python is selected with the default imports but Blockly tab can't be opened.
              When switching to version 1.4.5 I can open the THERMAL demo and view it online but there's no stable way of getting it transferred to the Fire running version 1.8.2 as the internet connection to the code platform seems to be very unstable, after several attempts to upload some code it will state that it's UPLOADING (on the screen of the device) but it doesn't succeed as it disconnects from the cloud where I think it's supposed to get the code from.
              The cloud icon then turns red.
              Sometimes it also remains green but still doesn't succeed in getting the code.
              • bob_isatB Offline
                bob_isat
                Great Job guys!
                Would have documentation related to the LORAWAN Module blocks ?
                Kind Regards,
                bob_isat
                  capacious @capacious
                  @m5stack any idea when the Desktop IDE containing UiFlow version 1.8.2 will be available?
                    Cant connect M5Stamp to Uiflow. firmware installed but not connecting and no wifi host
                    • OyczEO Offline
                      OyczE @ajb2k3
                      @ajb2k3 said in UIFlow 1.8.2:
                      remove Connection to pin0 and EN
                      If programator is connected device is in the download mode.
                        ajb2k3 @OyczE
                        @mati pins not connected.
                        going to try reflashing uiflow.
                          Dario @felmue
                          Hello @m5stack, I'm facing the same problem reported by @felmue with Core 2 and GoPlus2. Are you working on this bug?
                            ciconde @Dario
                            @dario @m5stack I have the same problem here. Is it going to be fixed?
