    AtomDTU NB-IoT not detecting SIM card
    8 Posts 3 Posters 11.4k Views
    • G Offline
      gmang
      Hi, I have tried two different ATOMDTU/NB-IoT modules and two different Sim cards but AT commands show Sim not detected. Any advice?
      see details from AT test:
      ati
      SIM7020G R1910
      OK
      at+gmm
      SIM7020G
      OK
      at+gmr
      1910B03SIM7020G
      OK
      at+gsn
      86151xxxxxxxxxx
      OK
      at+cgsn
      86151xxxxxxxxx
      OK
      at+cpin?
      +CME ERROR: SIM not inserted
      See does not detect sim card
      also LED status is:
      red=on
      blue= quick flash once per second
        Hello @gmang
        have you inserted the SIM card in the correct orientation? According to the second picture here the orientation seems to be up side down and the cut edge towards the outside (which for me was a bit counter intuitive.)
        • G Offline
          gmang
          • G Offline
            gmang @felmue
            RESOLVED: I had the sim card backwards. even though there is a big picture of how to insert it, i still inserted it cut-side first out of habit.
            Thanks for pointing it out.
            • G Offline
              gmang
              I also noted there is no way to set the APN details using UIFlow.
              I see that using M5Burner one can set the apn using the configuration button on Core, but not on UIFlow_Lite.
              Any advice to add APN setup and still use UIFlow
                MTal @gmang
                @gmang same here, I also need to change the APN from UIFLOW, did you already solved it?
                  Hi guys
                  to set the APN you could try to add an Execute code block with the following content:
                  dtu_nb.send_at_cmd("AT+CGDCONT=1,\"IP\",\"your_apn_here\"")
                  Please note the string quoting \" and replace your_apn_here with the one you intend to use.
                    MTal @felmue
                    @felmue Thank you Felix!
