    Mozzi sound synthesis library for Arduino - how to make it work on the Core2
    15 Posts 3 Posters 27.6k Views 1 Watching
    • O Offline
      oscillator
      Hi!
      Has anyone got the Mozzi library to work on the M5Stack Core2? It now has support for ESP32.
      I can compile Mozzi examples but don't know how to get audio output through the internal speaker.
      Mozzi: link
      Any help welcome!
      • O Offline
        oscillator @oscillator
        OK, so I think I have figured out how to make Mozzi sound through the internal speaker.
        In AudioConfigESP32.h change these lines to:
        // Set output mode
        #define ESP32_AUDIO_OUT_MODE PT8211_DAC
        // For external I2S output, only: I2S_PINS
        #define ESP32_I2S_BCK_PIN 12
        #define ESP32_I2S_WS_PIN 0
        #define ESP32_I2S_DATA_PIN 2
        (Ref: https://github.com/m5stack/M5-ProductExampleCodes/blob/master/Core/M5Core2/Arduino/record/record.ino)
        It seems to work, even though the Core2 uses the NS4168 I2S amp.
        In your code, put this at the top:
        #include <M5Core2.h>
        obviously, and in the setup():
        M5.Axp.SetSpkEnable(true);
        Put
        M5.update()
        in the updateControl() function.
        Also, in the Arduino IDE, set PSRAM: Disable.
        O 1 Reply Last reply Reply Quote 2
        • O Offline
          So now I've got a drum machine with 6 drum sounds (VA - not samples), and a bass synth up and running.
          I have created a simple editor for the drum sounds -- on to make the synth note editor and the synth sound editor (it has selectable waveforms, a LPF and an ADSR envelope, plus a 2nd detunable oscillator).
          • O Offline
            oscillator
            And here are the synth sound editor and the piano roll where you enter/edit the notes for the synth.
            • O Offline
              oscillator
              Here is the main menu. The engine is running three editable synths and a 5 voice drum machine (kick, snare, hihat open/closed, tom hi/lo, clap/crash).0_1631826372496_main.jpg
              • O Offline
                oscillator
                Drum sound editor
                and drum editor!
                • O Offline
                  oscillator
                  Song mode (arranging sequences in programmed order)
                  and a primitive though useful mixer for the three synths and all the drum sounds!
                  • O Offline
                    oscillator
                    Last thing on the list is data save/load (maybe even MIDI export), sequence copy function, demo, manual. Then I will release the project under a GPL license.
                      AgreeDK @oscillator
                      @oscillator looking forward to try it 👍
                      • O Offline
                        oscillator @AgreeDK
                        @agreedk said in Mozzi sound synthesis library for Arduino - how to make it work on the Core2:
                        Thanks a lot @AgreeDK, just a few more days and it will be finished! :)
                        • O Offline
                          oscillator
                          The finished project with source code and video demo:
                          https://community.m5stack.com/topic/3584/oscpocketm-portable-beat-production-tool-for-the-m5stack-core2
                            AgreeDK
                            Great work, got it installed, looks nice, now i just need time to Play with it.
                            O 1 Reply Last reply Reply Quote 1
                            • O Offline
                              oscillator @AgreeDK
                              Thank you! :)
                              I've got audio output using the DAC to work now so it is easy to output the sound to a speaker or mixer. The instructions are in the updated PDF manual.
                                rodberry @oscillator
                                @oscillator congratulations Staffan, I'm a year late to the party but just wanted to say this is a lot of fun and I really appreciate the thorough documentation and the very readable code (speaking as a C-phobic beginner programmer).
                                I'm planning to make this into a module for my AE format modular synth. For now, I'll start by just feeding it into a converter but will eventually get the other components organised to make it work nicely in the system with my other modules. At least you have given me a nice wagon to fall off! :)
                                • O Offline
                                  oscillator @rodberry
                                  @rodberry said in Mozzi sound synthesis library for Arduino - how to make it work on the Core2:
                                  Cool, I am glad you find it useful! The AE modular seems great.
                                  I can also recommend the Daisy Seed, for which I've done a few projects:
                                  https://www.oscillator.se/opensource/#daisy
                                  Good luck with your projects -- and your music! :)
