more panels in a APP made with uiflow
Hi all,
I'm a novice of M5stack core2 and it is a straordinary item ..
One question:
is possible , using UIFLOW, to have more panels in the same app?
I mean, iwould create an app like the Demo installed, where if i touche a button i can have different panel with different layout and items.
Is it possible?
Thanks -
@infor_mare Anyone can reply to this post?
SO i think that it is not possible in M5stack core2 ... no method to change a screen when i push a button??
Thanks -
Nothing is impossible, in UI Flow you can do it by changing the UI coordinate position, but if you have a lot of page. we suggest you use the arduino. (use the canvas buffer to create multi page)
Sorry been to busy to check.
Now way would be to create separate functions for each page but add the screen clean block to the beginning of the function loop.
