    Core2 MQTT fails to subscribe on SSL=True
    mqtthivemq
    9 Posts 3 Posters 12.6k Views 1 Watching
      alexanders
      Hello everyone
      I have trouble with connecting my Core2 to HiveMQ using MQTT.
      What works well so far:
      • Connecting to a public MQTT broker (hivemq or mosquitto) with no auth (and no SSL) works perfectly fine.
      • Connecting to my private cloud broker works and I can send messages (from core2 to hivemq) when using the 'execute code' block.
      What does not work and drives me kind of crazy is that I don't receive any messages on the topics I subscribed to -- when being connected to the private cloud instance using SSL.
      Any hints on what is wrong are greatly appreciated :)
      Cheers, Alex
        Well, according to that image, you are missing the SSL codes, keys and certificates.
        • felmueF Online
          Hello @alexanders
          it looks like the generated micropython code is missing the statement to actually subscribe. I have to add something like below, in an Execute Code block, just before the mqtt start block to make the subscription work:
          m5mqtt.subscribe(str('kesabi'), fun_kesabi_)
          • felmueF Online
            Hello @ajb2k3
            afaik, the client keyFile and certFile are optional and only required if the MQTT broker is setup to verify the MQTT client. Or am I missing something?
              If you check out the Execute Code block the params are different.
              For some reason there is an oddity with security lately that if SSL is set to true in MicroPython the the files are required.
              Also the main program functions need to be run in a loop placed after the MQTT Start block.
              • felmueF Online
                Hello @ajb2k3
                ah, ok, thank you for the information. I was not aware of that.
                  ajb2k3 @felmue
                  @felmue said in Core2 MQTT fails to subscribe on SSL=True:
                  Hello @ajb2k3
                  No worries, it's not a well know feature.
                    alexanders
                    Thanks a lot @ajb2k3 and @felmue for your swift responses! Good point with the subscribe statement -- and thanks for pointing out that I need to set keys and certs, I wasn't aware of that.
                    I'm sure your answers will help others, too :)
                    Cheers, Alex
                      ajb2k3 @alexanders
                      @alexanders thanks to you question, I have now added a paragraph about this to my book which will hopefully get an update by the end of the month!
