    [fixed]atomlite 1.9.7 name 'wlan' isn't defined
    4 Posts 2 Posters 7.7k Views
      mm-uiflow
      if i use the original network functions i get:
      File "flow/m5cloud.py", line 82, in _exec_fun
      File "<string>", line 39, in <module>
      NameError: name 'wlan' isn't defined
      i want to check what ip adress etc is set.
      all original network functions dont work. Smart config the same
        Hello @mm-uiflow
        I've tried UiFlow firmware 1.9.7 and 1.9.8 and with below commands (copied from the Python tab in flow.m5stack.com) I can print IP address etc.
        from m5stack import *
        from m5ui import *
        from uiflow import *
        import network
        wlan = network.WLAN(network.STA_IF)
        print(wlan.ifconfig())
          mm-uiflow
          @felmue said in atomlite 1.9.7 name 'wlan' isn't defined:
          if i just use the python code like you it works. Maybe i should create a custom block for that
            mm-uiflow
            wlan = network.WLAN(network.STA_IF) is 0_1654418854491_a0cdea9b-ae52-4361-82e6-68b7f114500a-image.png
            i didnt used create station interface because of that wlan wasnt defined!
