    M5stack fails to connect with blynk
    6 Posts 3 Posters 9.0k Views
      mm-uiflow
      Hello guys, i tried to run blynk, but i canot connect my atomlite's to blynk. i tried port 8080, 443 and 80 but the devices doesnt shows up in blynk as Online here is my configuration
      print('Start')
      wlan = network.WLAN(network.STA_IF)
      blynk1 = blynk.Blynk(server='blynk.cloud', port=80, token='XXXX', heartbeat=30)
      blynk1.run()
      m5mqtt.start()
      Any ideas?
      • felmueF Online
        Hello @mm-uiflow
        I think you need to put the ‘blynk1.run()’ statement in the loop.
          mm-uiflow
          I created a timer 0_1654770167257_78ecc3dc-435e-4d07-a135-6f5c94cdf6df-image.png
          and every 500 ms its called. still no connection
          in Debug i see the prints start and loop :
          i only used the AUTH_TOKEN, in bylnk cloud there are more things defined, you think this is the problem?
          • felmueF Online
            Hello @mm-uiflow
            yes, I think to successfully connect to blynk.cloud.com the template id is required as well. See here - check section [IMPORTANT] a bit down the page.
            I've done a quick test with Arduino Blynk code and my M5Core2 connected immediately. But with UIFlow my M5Core2 doesn't connect at all.
            I think UIFlow Blynk blocks need to be adapted to the new template id requirement.
              You can't connect to Blynk 2.0 until there is a big rebuild of the firmware as blynk uses the Virtual twin aka template method to connect whereas the old Blynk just used the username password combo.
                Not only that but the OLD password system has been upgraded to use certificates and encryption keys.
