PaHUB + ENVIII pressure reading issue
Using an Atom Matrix with a PaHUB, a TVOC/eCO2 unit and an ENVIII gives a strange pressure result.
The pressure value reads about 5 times the actual pressure level. This is the same whether the ENV is solo, or the other sensor is connected. Other readings seem to be working as expected,
When the ENVIII is connected on its own the pressure readings are as expected.
from m5stack import *
from m5ui import *
from uiflow import *
import wifiCfg
from m5mqtt import M5mqtt
import time
import unitrgb.set_screen([0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0xFFFFFF,0,0,0,0])
tvoc_2 = unit.get(unit.TVOC, unit.PAHUB1)
pahub_0 = unit.get(unit.PAHUB, unit.PORTA)
env3_0 = unit.get(unit.ENV3, unit.PAHUB0)tempdata = None
humdata = None
pressdata = None
iapbase = None
tvoc = None
basetvoc = None
co2 = None
baseco2 = None
h2 = None
eth = NonewifiCfg.doConnect('', '')
m5mqtt = M5mqtt('atomenv', '192.168.178.14', 1883, '', '', 600)
m5mqtt.start()
tvoc_2.set_iaq_baseline(35187, 35502)
while True:
tempdata = env3_0.temperature
humdata = env3_0.humidity
pressdata = env3_0.pressure
m5mqtt.publish(str('temperature'),str(tempdata))
m5mqtt.publish(str('humidity'),str(humdata))
m5mqtt.publish(str('pressure'),str(pressdata))
wait(2)
iapbase = tvoc_2.get_iaq_baseline()
tvoc = tvoc_2.TVOC
basetvoc = tvoc_2.baseline_TVOC
co2 = tvoc_2.eCO2
baseco2 = tvoc_2.baseline_eCO2
h2 = tvoc_2.H2
eth = tvoc_2.Ethanol
m5mqtt.publish(str('IAPbaseline'),str(iapbase))
m5mqtt.publish(str('TVOCnow'),str(tvoc))
m5mqtt.publish(str('TVOCbase'),str(basetvoc))
m5mqtt.publish(str('CO2'),str(co2))
m5mqtt.publish(str('CO2base'),str(baseco2))
m5mqtt.publish(str('H2'),str(h2))
m5mqtt.publish(str('ethanol'),str(eth))
wait_ms(2) -
@boomvalt I have the same issue. The ENV III Unit works well when connected directly to Port A, it displays the temperature, humidity, and pressure correctly, but when I connect the sensor to PaHub, the temperature and humidity have still correct values, but the pressure is static and shows a negative number something like -513233.2. I have two units and with both, I have the same results.
Were you able to solve this issue?
Regards.
Alvaro B
Maybe its because PaHUB and sensor QMP6988 have same I2C adresse 0x70.
Possibly modify PaHUB adresse to 71 by soldering on the component. -
@octopuss you are correct.
Because the ENVIII has the same I2C address, you are getting corruption from the hub -
@ajb2k3 By the way , now we speaking about I2C do you know why Icannot use PaHub and Hat 8 servo in same time ? Is not the same I2C 0x38 vs 0x70 ? Its seem the first i initiate in script will be the only will work.
@octopuss I don't know but it may be a power issue. Mine is sat in a box waiting for me to connect it to the project
Hello guys
as stated before PaHUB and ENV III units cannot be used together as they share the same I2C address 0x70 by default. That said the I2C address of the PaHUB unit can be modified (let's say to use 0x71) to avoid the conflict.
And in UIFlow2 it is possible to use a PaHUB unit with modified I2C address. So in UIFlow2 add an ENV III unit and select PAHUB as BUS (which automatically will add a PaHUB unit as well). Then replace the resulting
Init env3_0block with anExecute codeblock with the following content:env3_0 = ENVUnit(i2c=PAHUBUnit(i2c=i2c0, channel=0, address=0x71), type=3)
Note: ENV III unit is connected to the first channel of the PaHUB unit, e.g. channel 0.
Complete Micropython code:
import os, sys, io import M5 from M5 import * from hardware import * import time from unit import * label0 = None label1 = None label2 = None i2c0 = None pahub_0 = None env3_0 = None def setup(): global label0, label1, label2, i2c0, pahub_0, env3_0 M5.begin() label0 = Widgets.Label("label0", 3, 4, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18) label1 = Widgets.Label("label1", 2, 22, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18) label2 = Widgets.Label("label2", 2, 44, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18) i2c0 = I2C(0, scl=Pin(1), sda=Pin(2), freq=100000) env3_0 = ENVUnit(i2c=PAHUBUnit(i2c=i2c0, channel=0 , address=0x71), type=3) def loop(): global label0, label1, label2, i2c0, pahub_0, env3_0 M5.update() time.sleep(1) label0.setText(str(env3_0.read_temperature())) label1.setText(str(env3_0.read_pressure())) label2.setText(str(env3_0.read_humidity())) if __name__ == '__main__': try: setup() while True: loop() except (Exception, KeyboardInterrupt) as e: try: from utility import print_error_msg print_error_msg(e) except ImportError: print("please update to latest firmware")BTW: In UIFlow1 I have not been able to figure out how (if at all) it is possible to use a PaHUB unit with non default I2C address.
Felix -
F felmue referenced this topic on
