    195 Posts 79 Posters 569.3k Views 13 Watching
    • IAMLIUBOI Offline
      IAMLIUBO
      Any issues related to uiflow 2.0 can be discussed here.
      UiFlow 2.0 website: link
      UiFlow 2.0 API Docs(WIP): link
      UiFlow 2.0 source code: link
      M5burner: download link
      Quick look: twitter link
      Burning firmware requires a login account (forum account), which will automatically bind the device to the account.
      More info wiil add late in here.
      M K dissyD K 4 Replies Last reply Reply Quote 3
        Looks a lot cleaner but only being able to select the Atom S3 make it difficult to test.
        • m5stackM Online
          m5stack @ajb2k3
          Ah, will support more device in the future,won't be long :)
            Hi guys
            • code modifications in Python view are lost without warning when switching back to block view.
            • in split view: which code will actually be executed? Block view or Python view?
            • IAMLIUBOI Offline
              IAMLIUBO @felmue
              @felmue said in UiFlow 2.0 Alpha verison discuss(how-to, bug, feature request or sometings):
              Mark this, and will fix this.
              For now, python area is only for look, any editing will reset when you click run button, will add lock button in the future. emmmm, in split view mode, if has some choose button will be better? User can choose which one to execute? We will talk this.
              Thanks @felmue !
                mchott
                For now it´s nearly the same like before and maybe the biggest innovations are in restructuring the UI and "under the UI".
                There is still no multiple views feature to make the display more usefull with the UIFlow?
                • IAMLIUBOI Offline
                  IAMLIUBO
                  @mchott said in UiFlow 2.0 Alpha verison discuss(how-to, bug, feature request or sometings):
                  yeah, multiple views feature I also want make it, pls give my team sometime, i think one day we can make it happen. We still have a lot of basic functionality to add for now.
                    Jruys
                    Potential bug: When I add a function, any blocks in there seem to go "disabled" - I have to manually enable every bit of it. After saving and loading, all blocks are disabled again.
                    Am I missing something?
                    Thanks - JW
                    • IAMLIUBOI Offline
                      IAMLIUBO @Jruys
                      @jruys
                      Sorry for that happened, we'll look into this.
                        flex
                        Bug in "get UTC time"
                        • year returned is +30 (2053 instead of 2023)
                        • month is OK
                        • day returned is -1 (17 instead or 18)
                        • hour is OK
                        • minute is OK
                        Bug in "get system uptime in seconds"
                        • value is increasing correctly second by second but the value returned is HUGE!!!
                          flex
                          problem with some m5Burner version 3 on OSX:
                          different versions where released on the website but they are all identified 3.0.0, which is confusing...
                          • the one of April 9 2022, which doesn't work with atomS3
                          • the one of January 13 2023 which works
                          you should increased the last one to 3.0.1 to avoid any confusion for long time users
                          Pascal
                            flex
                            Could you unlock from UIFlow 2 the capability to code in micropython…
                              ajb2k3 @flex
                              @flex What do you mean as you can work direct in micropython without UIFlow using REPL
                                @IAMLIUBO With the S3's having the internal USB adapter, the S3's can now act as USB drives.
                                Can we get a UF2 boot loader so that Stamp and Atom S3's can now be programmed like Microbit and Circuitpython devices (USB storage devices.)
                                  flex @ajb2k3
                                  UIFlow make it easier to upload and test code through the cloud and also to draft the screen UI on the atomS3
                                  F ajb2k3A 2 Replies Last reply Reply Quote 0
                                    flex @flex
                                    @flex
                                    And also rhrough the uIFlow cloud it is ok to develop through an ipad as it doesn’t offer USB-C to serial
                                      @IAMLIUBO Error with the TOF Unit with Alpha7
                                      Connected to Serial Port!
                                      >>> import gc
                                      >>> gc.collect()
                                      === import os, sys, io
                                      === import M5
                                      === from M5 import *
                                      === from hardware import *
                                      === from unit.tof import ToF
                                      === from unit import *
                                      === title0 = None
                                      === label0 = None
                                      === i2c0 = None
                                      === tof_0 = None
                                      === def setup():
                                      ===   global title0, label0, i2c0, tof_0
                                      ===   i2c0 = I2C(0, scl=Pin(1), sda=Pin(2), freq=100000)
                                      ===   tof_0 = ToF(i2c0)
                                      ===   M5.begin()
                                      ===   title0 = Widgets.Title("Title", 3, 0xFFFFFF, 0x0000FF, Widgets.FONTS.DejaVu18)
                                      ===   label0 = Widgets.Label("Text", 23, 58, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
                                      ===   title0.setText('TOF Unit')
                                      ===   label0.setFont(Widgets.FONTS.DejaVu9)
                                      === def loop():
                                      ===   M5.update()
                                      ===   label0.setText(str(((str('Distance: ') + str((tof_0.get_distance()))))))
                                      ===   try:
                                      ===     setup()
                                      ===     while True:
                                      ===       loop()
                                      ===     try:
                                      ===       print_error_msg(e)
                                      ===     except ImportError:
                                        File "<stdin>", line 28, in <module>
                                        File "<stdin>", line 23, in loop
                                        File "driver/vl53l0x.py", line 521, in get_distance
                                      AttributeError: 'VL53L0X' object has no attribute 'range'
                                        flex @flex
                                        @flex @IAMLIUBO @ajb2k3
                                        bug in "get UTC time" and "get system uptime in seconds" for AtomS3 and UIFlow2/micropython 1.19.1 is probably related to a confusion handling Unix time 1970 and Unix time 2000 (as 30 years difference returned)
                                        • teastainT Offline
                                          teastain @IAMLIUBO
                                            ajb2k3 @flex
                                            @flex Some people and groups cant use the cloud platform and so local programming like with the microbic and RPI is needed for them
                                            S W 2 Replies Last reply Reply Quote 0
