    195 Posts 79 Posters 570.9k Views 13 Watching
    • m5stackM Offline
      m5stack @ajb2k3
      Looks a lot cleaner but only being able to select the Atom S3 make it difficult to test.
      Ah, will support more device in the future,won't be long :)
        Hi guys
        • code modifications in Python view are lost without warning when switching back to block view.
        • in split view: which code will actually be executed? Block view or Python view?
        • IAMLIUBOI Offline
          IAMLIUBO @felmue
          @felmue said in UiFlow 2.0 Alpha verison discuss(how-to, bug, feature request or sometings):
          Mark this, and will fix this.
          For now, python area is only for look, any editing will reset when you click run button, will add lock button in the future. emmmm, in split view mode, if has some choose button will be better? User can choose which one to execute? We will talk this.
          Thanks @felmue !
            mchott
            For now it´s nearly the same like before and maybe the biggest innovations are in restructuring the UI and "under the UI".
            There is still no multiple views feature to make the display more usefull with the UIFlow?
            • IAMLIUBOI Offline
              IAMLIUBO
              @mchott said in UiFlow 2.0 Alpha verison discuss(how-to, bug, feature request or sometings):
              yeah, multiple views feature I also want make it, pls give my team sometime, i think one day we can make it happen. We still have a lot of basic functionality to add for now.
                Jruys
                Potential bug: When I add a function, any blocks in there seem to go "disabled" - I have to manually enable every bit of it. After saving and loading, all blocks are disabled again.
                Am I missing something?
                Thanks - JW
                • IAMLIUBOI Offline
                  IAMLIUBO @Jruys
                  @jruys
                  Sorry for that happened, we'll look into this.
                    flex
                    Bug in "get UTC time"
                    • year returned is +30 (2053 instead of 2023)
                    • month is OK
                    • day returned is -1 (17 instead or 18)
                    • hour is OK
                    • minute is OK
                    Bug in "get system uptime in seconds"
                    • value is increasing correctly second by second but the value returned is HUGE!!!
                      flex
                      problem with some m5Burner version 3 on OSX:
                      different versions where released on the website but they are all identified 3.0.0, which is confusing...
                      • the one of April 9 2022, which doesn't work with atomS3
                      • the one of January 13 2023 which works
                      you should increased the last one to 3.0.1 to avoid any confusion for long time users
                      Pascal
                        flex
                        Could you unlock from UIFlow 2 the capability to code in micropython…
                          ajb2k3 @flex
                          @flex What do you mean as you can work direct in micropython without UIFlow using REPL
                            @IAMLIUBO With the S3's having the internal USB adapter, the S3's can now act as USB drives.
                            Can we get a UF2 boot loader so that Stamp and Atom S3's can now be programmed like Microbit and Circuitpython devices (USB storage devices.)
                              flex @ajb2k3
                              UIFlow make it easier to upload and test code through the cloud and also to draft the screen UI on the atomS3
                              F ajb2k3A 2 Replies Last reply Reply Quote 0
                                flex @flex
                                @flex
                                And also rhrough the uIFlow cloud it is ok to develop through an ipad as it doesn’t offer USB-C to serial
                                  @IAMLIUBO Error with the TOF Unit with Alpha7
                                  Connected to Serial Port!
                                  >>> import gc
                                  >>> gc.collect()
                                  === import os, sys, io
                                  === import M5
                                  === from M5 import *
                                  === from hardware import *
                                  === from unit.tof import ToF
                                  === from unit import *
                                  === title0 = None
                                  === label0 = None
                                  === i2c0 = None
                                  === tof_0 = None
                                  === def setup():
                                  ===   global title0, label0, i2c0, tof_0
                                  ===   i2c0 = I2C(0, scl=Pin(1), sda=Pin(2), freq=100000)
                                  ===   tof_0 = ToF(i2c0)
                                  ===   M5.begin()
                                  ===   title0 = Widgets.Title("Title", 3, 0xFFFFFF, 0x0000FF, Widgets.FONTS.DejaVu18)
                                  ===   label0 = Widgets.Label("Text", 23, 58, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
                                  ===   title0.setText('TOF Unit')
                                  ===   label0.setFont(Widgets.FONTS.DejaVu9)
                                  === def loop():
                                  ===   M5.update()
                                  ===   label0.setText(str(((str('Distance: ') + str((tof_0.get_distance()))))))
                                  ===   try:
                                  ===     setup()
                                  ===     while True:
                                  ===       loop()
                                  ===     try:
                                  ===       print_error_msg(e)
                                  ===     except ImportError:
                                    File "<stdin>", line 28, in <module>
                                    File "<stdin>", line 23, in loop
                                    File "driver/vl53l0x.py", line 521, in get_distance
                                  AttributeError: 'VL53L0X' object has no attribute 'range'
                                    flex @flex
                                    @flex @IAMLIUBO @ajb2k3
                                    bug in "get UTC time" and "get system uptime in seconds" for AtomS3 and UIFlow2/micropython 1.19.1 is probably related to a confusion handling Unix time 1970 and Unix time 2000 (as 30 years difference returned)
                                    • teastainT Offline
                                      teastain @IAMLIUBO
                                        ajb2k3 @flex
                                        @flex Some people and groups cant use the cloud platform and so local programming like with the microbic and RPI is needed for them
                                        S W 2 Replies Last reply Reply Quote 0
                                          sgu @ajb2k3
                                          This is true. If you build an internal application for a company on the internal network, the devices will not have cloud access or they have to switch always the wlan.
                                          A Desktop uiflow version is still a good alternative to the cloud version !
                                            sgu
                                            Ui Flow 2.0 looks nice. But it lacks functionality.
                                            Tested with a new Core S3 and wanted to test out the built in Camera. But how to do it either in micropython or with blockly ?
                                            Once you start selling the devices, the software must be ready and support all features of the device.
                                            In my case I wanted to test the camera if it is possible to use the built in camera as a barcode reader, this would be a great application.
                                            Second question to uiflow 2.0: Where have the examples gone ?
                                            Even as an experienced programme, the demos are a good starting point for testing out a device or a unit.
                                            Third question: How about the support of the stackable-modules for the Core S3 ? How to access them in the UiFlow 2.0 ? can we reuse the modules for the older M5 Stack models ?
                                            ajb2k3A IAMLIUBOI 2 Replies Last reply Reply Quote 0
