šŸ¤–Have you ever tried Chat.M5Stack.com before asking??šŸ˜Ž
    Goplus2 with M5Stack core -> Motor to slow
    9 Posts 4 Posters 9.3k Views 1 Watching
      TheAlphaGhost
      I have a issue with GoPlus2 and a RC Motor.
      If i use the motor on a raspberry with L298N Motor driver the speed ist very fast.
      On M5Stack core with GoPlus2 and Full Speed 100 (+127) the motor runs 1/3 of the speed from the L298N. What's the issue in M5 GoPlus2 ? Why the motor is too slow ?
      If i connect on the GoPlus2 a external battery with 7.4V it makes no difference.
      Has anyone a idea, how i can drive faster my dc motor with the GoPlus2 Modul ? It looks like the issue is "not" on motor or power voltage side. Must be on GoPlus2.
      • teastainT Offline
        teastain @TheAlphaGhost
        @thealphaghost The MotorWriteSpeed is an int, which could be at least 255.
        Could you try a number greater than +127 and see if this hack works?
        -Terry
          TheAlphaGhost
          Hi @teastain
          128 reverse the direction from forward to backward
          • teastainT Offline
            @thealphaghost OK! thanks for trying!
            Good luck!
              The voltage output from the go2 is only 5V
                TheAlphaGhost @ajb2k3
                WHAT? Really?!
                Then thats my problem! I cant find this information in the docs. It make no sense, if i can connect a external 12V Batterie…
                ajb2k3A teastainT 2 Replies Last reply Reply Quote 0
                  ajb2k3 @TheAlphaGhost
                  @thealphaghost when I tried running a 12v loco off a 12v battery I was only getting 5v out
                  • teastainT Offline
                    @thealphaghost You COULD connect the L298N using the GPIO on the side of the Core Basic?
                    Or if you NEED the GoPlus2 could you use three of the GroveB outputs?
                      Hello @TheAlphaGhost
                      have a look at the schematic here. Input voltage goes through the IN Power Buck DC-DC and the output is 5 V, which is used for servos and DC motors.
                      With your input, this post could be even better šŸ’—
