    Ideas, helping M5Stack document stuff...
    29 Posts 9 Posters 129.8k Views 4 Watching
      ajb2k3 @m5-docs
      @watson 在 Ideas, helping M5Stack document stuff... 中说:
      To everyone:
      Please pay more attention to github and docs.
      https://github.com/m5stack
      https://m5stack.github.io/m5-docs/#/en/product_documents
      lots of 404 missing pages.
      • m5-docsM Offline
        m5-docs @ajb2k3
        I am fixing it.
        M5Stack documentation URL
        https://docs.m5stack.com
        • m5-docsM Offline
          m5-docs @Kabron
          @kabron
          I am adding schematic files
          https://github.com/m5stack/M5-Schematic
          Here a catalog
          https://github.com/m5stack/M5RepoCatalog
          RopR KabronK 2 Replies Last reply Reply Quote 0
          • RopR Offline
            Rop @m5-docs
            @watson Excellent!! Stuff is being added!! Could you also add the schematics, 3D, etc. of all the bases, including the FACES base and the FACES keyboards ?
            • KabronK Offline
              Kabron @m5-docs
              M5Fire schematic still TopSecret?
                PlayTheGame
                @watson
                M5Fire schematics?
                Its fine to used the altered pin maps as basis but be aware your leaflets contain errors.
                Fire has an undocumented I2C device on the bus, most probably the power management IC.
                M5Camera really I2C SDA on G22 not G25? Schematics?
                M5Core
                Not up to date, connectors missing
                M BUS
                HPWR?
                m5-docsM 2 Replies Last reply Reply Quote 0
                • m5-docsM Offline
                  m5-docs @Rop
                  @rop
                  OK, i am going to talk with our boss about that. Thanks your support.
                  • m5-docsM Offline
                    m5-docs @Kabron
                    @kabron
                    Hey kabron. Fire is not a topsecret. I consider that there are few different between M5Core Basic, M5Core GRAY, M5Fire and the main board(M5Core WHITE) of M5GO. They are simliar to each other. So we just supply the schematic of M5Core Basic.
                    Please read this doc. I updated it just now.
                    https://github.com/m5stack/M5-Schematic/blob/master/Core/hardware_diff_between_m5cores.md
                    loborisL KabronK 2 Replies Last reply Reply Quote 0
                    • m5-docsM Offline
                      m5-docs @PlayTheGame
                      @playthegame
                      Hi
                      the GROVE Interface(I2C) of M5Camera is G12 and G13
                      The IIC address of MPU9250 is 0x68
                      Here's the docs about M5Fire and M5Camera
                      M5Fire :
                      https://m5stack.github.io/m5-docs/#/en/product_documents/m5stack-core/m5core_fire
                      M5Camera:
                      https://m5stack.github.io/m5-docs/#/en/product_documents/units/unit_m5camera
                      • m5-docsM Offline
                        @playthegame
                        Device IIC address
                        mpu9250 0x68
                        mpu6050 0x68
                        IP5306 0x75
                        MAG3110 0x0E
                        the arly version of M5Fire was built in MPU6050 + MAGE3110, but we change MPU6050 + MAGE3110 to MPU9250.
                        If your m5fire scan i2c address is 0x68 0x75 0x0e, it means your m5fire maybe is previous version.
                        The iic addrss of new m5fire will be 0x68, 0x75
                        The iic addrss of m5core basic will be 0x75, because it has not own mpu9250
                        • loborisL Offline
                          loboris @m5-docs
                          @kabron
                          If it is not a secret, you should make the schematics of all the boards available. How hard can it be to put them on GitHub or somewhere else. Especially if you want those boards to be used by developers who want to do with them more than just playing with nice boxes.
                          • KabronK Offline
                            Kabron @m5-docs
                            It is better to see once than read 100 times bla-bla-bla
