Stack is dead :(
after flashing the device, the device does not turn on!
http://forum.m5stack.com/topic/67/micropython-on-webide-1-prepare-and-hello-world
how to revive the device?
how to flash the device in its original state and discard the micro python?
This post is deleted! -
press the button A when reset, pls try
you mean Arduino?
Have you tried to reflash using sepressif flashing tool and FW that are on github?
no, need an instruction
http://iot-bits.com/esp32/esp32-flash-download-tool-tutorial/
I think you should be able to flas stock esp and run via arduino after. I have done it with esp8266
@snmcma 在 Stack is dead :( 中说:
@m5stack 在 Stack is dead :( 中说:
you mean Arduino?Yes, Arduino
can throw off the firmware file for overwriting in m5? and a screenshot how to write down
you can throw off all the firmware files with the instruction how to return to the initial state, micropyton does not suit me. I reprogrammed it as an esp32 dev module, unfortunately in m5stack mode it is not programmed
