    How to use the ExpPort For Core2 module
    4 Posts 2 Posters 3.8k Views
      digiponta
      I have confirmed that port E is working properly. However, I can't get port B to port D up. There are only two UI Flow menu selections, Port A and Port E for an Unit. I can't find the specs for the 4 DIP switches on the ExpPort For Core2 module. I need a clearer and more polite explanation of the ExpPort For Core2 module.
      Thank you in advance
      Hirofumi
        Do you mean this chart that is on the product page?
        alt text
        or the information on this page?
        https://docs.m5stack.com/en/module/extport_for_core2?ref=pfpqkvphmgr
          digiponta
          @ajb2k3 said in How to use the ExpPort For Core2 module:
          Thank you for your reply.
          Of course, I understand this information, but I'm asking because it doesn't work according to the information.
          Thank you in advance.
          Hirofumi
            Ports B and C are not controlled by the board, they are connected directly to the bus and handled directly by the core.
            As to D and E which are handled by the base.
            Ports B and See only. become available when you select units that require ports B and C
