    Power Supply of COM.LTE (SIM7600)
    16 Posts 3 Posters 15.4k Views 1 Watching
      DanK @felmue
      Hi @felmue
      thanks a lot for your explanation! Before posting here, I actually did search for a schematic of the green SIM7600 board. With no success. Would be very helpful, to have these schematic too, not only the one of the base board. Maybe even the adding of some capacitor behind the on-board regulator could solve my problem.
      I have not only the COM.LTE, but also the GPS module, which draws current from the 3.3v though.
      I actually already use an external power supply, added to my custom module. It's a PRM3W-E12-S5, a 5V-output isolated regulator. It's output is connected to the HPWR-Bus. Inside the M5stack-core-basic, I soldered a wire from HPWR to the input fuse.
      While this works more or less correctly, I tend to have more problems connecting to the IOT through the SIM module, if this external power supply is used. It's working better, if I use the USB for power supply.
      I will try to reverse-engineer the green SIM7600 board, and add a backup capacitor.
      Will report back.
      Kind regards,
      Dan
        DanK @DanK
        On my COM.LTE board, the ASM1117-3.3 has its Adjust Pin connected to GND. That makes this a 3.3V output regulator. That's not enough.
          Hello @DanK
          where on the board did you find the AMS1117? Does it have a different marking on its case?
            DanK @felmue
            Hi @felmue
            That's it: AMS1117. The 33 is written on the second line, on the left under the dirt.
            Regards, Dan
              DanK @DanK
              There is 0ohm between the adjust pin of the AMS1117 and the GND pins of the board.
                Hello @DanK
                interesting. My COM.LTE board looks like this one.
                No AMS1117 on that board.
                  DanK @felmue
                  Hello @felmue
                  well, what can I say but: That's weird.
                  Now, just look at M5's pictures of the module. On their doc site, it's yours. On the shop site, it's mine...
                  I think we get to the core of the problem. I just measured the voltage, when USB is connected on the M5stack Core Basic 2.7, at the input of ther regulator: 4.3V ! At its output it has 2.8V. That's way off the 3.4V limit.
                  So the issue is not so much the type of regulator, but the question whether or not we can use internal power supply or not. My understanding of M5's specification is that external power supply is explicitly needed only with Core 2 and Fire. If that wasn't the case, why connect the M-Bus voltage to the module at all.
                  It seems to be clear now, that power supply MUST be external.
                  @M5 : Please comment, thanks!
                    mtylerjr @DanK
                    @dank said in Power Supply of COM.LTE (SIM7600):
                    Do you have a link to the shop site that shows the board that looks like yours?
                      DanK @mtylerjr
                      @mtylerjr
                      Link shop: https://shop.m5stack.com/products/com-lte-modulesim7600g
                      Link doc: https://docs.m5stack.com/en/module/comx_lte
                      Worse: They not even changed product code. Both have product no: M031-A.
                      The first item I bought was the one on the doc site, the one that felmue showed. That worked fine. First customer happy. Then I bought 10 new ones, without being told it's another board inside. Now customers are very unsattisfied. Me too.
                        Hello @DanK
                        well, there is another difference. The one I have is a SIM7600G (which is only CAT1) whereas it seems the shop now sells SIM7600G -H. The H actually makes it a CAT4 device (as advertised). See my post here.
                        BTW: mine had very poor reception until I realized the antenna cable was connected to the GPS connector by mistake. My post at the time.
                          DanK @felmue
                          Hi @M5,
                          One more attempt to appeal to your sense of responsibility. I powered the SIM7600G-H Module with 5.0V, between Vin and GND. I measured the following voltages between the pins of the AMS1117 voltage regulator and GND:
                          1: (GND/Adjust): 0.0V
                          2: Vin: 3.75V
                          3: Vout: 2.85V
                          If the SIM7600 modem is connected to the output of the regulator, which is assumed, then the minimum operating voltage is significantly undershot.
                          Please respond to these findings and publish a diagram of the green piggyback circuit with the SIM7600 modem. Of particular interest is the connection between Vin and the input of the regulator. Why aren't the 5.0V input voltage making it to the input of the regulator?
                          Thanks and kind regards,
                          Dan
                            Hello @DanK
                            looking at the picture you've posted again I don't think the AMS1117 is the regulator for the SIM7600G-H. I think the 6 pin IC labelled JB3N (or so) on the right side is - the traces from Vin also go there. The output of that IC goes through the coil (squarish black thing) which is then feed into the AMS1117 pin 3. So my guess is that the SIM7600G-H is actually powered from the 3.75 V coming out of the coil. This would almost match the recommended voltage of 3.8 V.
                            Note: I am obviously guessing here as I do not have this particular green board to verify myself.
                            While we do not have the schematic of the green board we do have the pinout of the SIM7600G-H so you could double-check (if you haven't already) what the actual voltage is that goes into VBAT (pin 38, 39, 62, 63).
                            Note: if my above assumptions are correct then I don't know what the AMS1117 is doing and what it's output voltage is needed for. Well, maybe it's used for the active GPS antenna.
                              DanK @felmue
                              Hi @felmue
                              you are perfectly right! The SIM7600G-H is not powered by the AMS1117. It's actually the regulator's input voltage that also goes to the Vbat of the SIM modem (Pins 62 and 63).
                              It's good to know the SIM modem is powered correctly.
                              But: what ever the AMS1117 does, it's NOT used correctly.
                              Thanks again for your help!
                              Kind regards, Dan
                                Hello @DanK
                                actually there is an AMS1117 version with exactly the output voltage you measured: 2.85 V - coincidence?
                                From the AMS1117 datasheet - feature list: Three Terminal Adjustable or Fixed Voltages* 1.5V, 1.8V, 2.5V, 2.85V, 3.3V and 5.0V
                                But yes, the input voltage is probably on the low side.
