    Kernel crashed when rotate the M5dial encoder fast
    8 Posts 3 Posters 5.8k Views 1 Watching
      codeblue
      Hi Team
      I was working on a small BLE-related project with M5Dial.
      Basically, the code allows you to select services with M5Dial's encoder, then press btnA to advertise it and hold the btnA to stop advertising.
      The code works just fine when you rotate the encoder slowly, but when you do it fast, it will throw following Errors randomly
      TypeError: '' object isn't callable。
      TypeError: 'dict_view' object isn't callable
      TypeError: 'list' object isn't callable
      or the kernel crashed and the device been reset.
      firmware Version: UIFlow alpha-29
      import ubluetooth
      import time
      from M5 import Widgets, Speaker, BtnA, update
      from hardware import Rotary
      class BLE_SERVER():
          def __init__(self,src_boards,dst_boards):
              self.ble = ubluetooth.BLE()
              self.isAdvertising=False
              self.rotary = Rotary()
              self.DST_APPS=dst_boards
              self.label0 = Widgets.Label("label0", 16, 101, 1.0, 0xf2f805, 0x000000, Widgets.FONTS.DejaVu24)
              Speaker.setVolumePercentage(0.3)
              Widgets.setBrightness(10)
              BtnA.setCallback(type=BtnA.CB_TYPE.WAS_CLICKED, cb=self.btnA_wasClicked_event)
              BtnA.setCallback(type=BtnA.CB_TYPE.WAS_HOLD, cb=self.btnA_wasHold_event)
          def btnA_wasClicked_event(self,state):
              try:
                  if not self.isAdvertising:
                      print('click0')
                      self.isAdvertising = True
                      self.label0.setText(str('advertising....'))
                      self.label0.setCursor(x=20, y=100)
                      self.label0.setVisible(True)
                      Widgets.setBrightness(1)
                      adv_app=self.DST_APPS[int((self.rotary.get_rotary_value()) % len(self.DST_APPS) - 1)]
                      self.start_advertising(adv_app)
              except Exception as e:
                  print('btnA_Clicked:',repr(e))
          def btnA_wasHold_event(self,state):
              try:
                  if self.isAdvertising:
                      print('hold0')
                      self.isAdvertising = False
                      self.label0.setText(str('adv stoped'))
                      self.ble.gap_advertise(None)
                  print('btnA_Holded: ',repr(e))
          def bt_irq(self,event, data):
              print('BLE_EVENT: ', event)
          def start_advertising(self,app):
              for i in range(3):
                  try:
                      SERVICE_UUID_SIM = ubluetooth.UUID(0xfff0)
                      RX_UUID_SIM = ubluetooth.UUID(0xfff1)
                      TX_UUID_SIM = ubluetooth.UUID(0xfff2)
                      SERVICE_NAME_SIM = app
                      CHAR_RX = (RX_UUID_SIM, ubluetooth.FLAG_WRITE | 0x04)
                      CHAR_TX = (TX_UUID_SIM, ubluetooth.FLAG_NOTIFY)
                      SERVICE_1 = (SERVICE_UUID_SIM, (CHAR_RX, CHAR_TX,) ,)
                      SERVICES = (SERVICE_1,)
                      time.sleep(0.5)
                      self.ble.config(gap_name=app, addr_mode=1)
                      adv_data_prefix = [0x02,0x01,0x06,len(SERVICE_NAME_SIM)+1, 0x09]
                      resp_d = b'\x11\x07'  + bytes(SERVICE_UUID_SIM)
                      ((char_rx, self.char_tx), ) = self.ble.gatts_register_services(SERVICES)
                      self.ble.gap_advertise(100,adv_data = bytes(adv_data_prefix) + SERVICE_NAME_SIM.encode('utf-8'),resp_data = resp_d)
                      print('start BLE advertising: ',app)
                      break
                      print('------------------------------------------advertising: ',repr(e))
                      time.sleep(3)
          def run(self):
              self.ble.active(True)
              self.ble.irq(self.bt_irq)  #CB
              list2 = [0xff0000, 0xff9900, 0xffff00, 0x33ff33, 0x33ffff, 0x3333ff, 0xcc33cc]
              while True:
                  update()
                  if not self.isAdvertising and (self.rotary.get_rotary_status()):
                      print(time.ticks_ms())
                      Speaker.tone(3000, 50)
                      Widgets.fillScreen(list2[int((self.rotary.get_rotary_value()) % len(self.DST_APPS) - 1)])
                      self.label0.setText(self.DST_APPS[int((self.rotary.get_rotary_value()) % len(self.DST_APPS) - 1)])
                  time.sleep(0.1)
      if __name__ == '__main__':
          u = BLE_SERVER(['A','B'],['BLE_C','BLE_D'])
          u.run()
      <========  after the code run, rotate the encoder fastly for 50+ times.
      26733
      26859
      27183
      27409
      click0
      start BLE advertising:  BLE_C
      <==  hold btnA here, but get an error.
      93335
      click0
      <<=======    hold btnA here, but kernel crashed.
      PROBLEM IN THONNY'S BACK-END: Exception while handling 'run' (ConnectionError: read failed: [Errno 6] Device not configured).
      See Thonny's backend.log for more info.
      You may need to press "Stop/Restart" or hard-reset your MicroPython device and try again.
        codeblue
        Hi Felix, can you help? @felmue
          Hello @codeblue
          it seems that adding a gc.collect() call after line self.ble.gap_advertise(None) prevents the crash/error.
            codeblue @felmue
            @felmue 我如果不用类的写法, 而直接写方法,程序跑起来就没问题, 也不需要 gc.collect()
            应该不是内存的问题, 因为崩溃的时候,或者报 TypeError: '' object isn't callable 的时候 hold0 还没输出, 说明还没进入btnA_wasHold_event函数, 有可能是btnA 设置回调的时候, 不能设置 self.xxxx 这样的对象函数?
            • lbuqueL Offline
              lbuque
              @codeblue The BtnA.setCallback method causes this exception.
              A temporary workaround:
                codeblue @lbuque
                @lbuque said in Kernel crashed when rotate the M5dial encoder fast:
                setCallback
                Thanks, will this be fixed in the future?
                • lbuqueL Offline
                  lbuque
                  @codeblue It will be fixed in the next version.
                    Hi guys
                    thank you for the insight - good to know.
