Connecting Env Unit and RFID Unit via Grove Hub on M5StickC
It looks like Env unit has 2 I2C addresses (92, 118)? But many times 92 will go away in the scan loop. Strange...
All I can think is that the two sensors are drawing too much power for the bus.
I have both units and also the hat versions. if I find time over the week end I may have some time to test but I may need a reminder on saturday.
Double check the address's. The published addresses are in Hex but they are displayed in binary on the screen!
@ws1088 Confirmed, the RFID Unit will not work with the ENV unit and will not work with the ENV hat
@ajb2k3 said in Connecting Env Unit and RFID Unit via Grove Hub on M5StickC:
Is the reason as you mentioned that there is not enough power? I guess not because you test it on the ENV hat with RFID unit. I noticed a lot of bus error (timeout), maybe it's a software issue? I am using UIFlow, btw. Are you using Arduino IDE and C++?
@ws1088 said in Connecting Env Unit and RFID Unit via Grove Hub on M5StickC:
Nope, only UIFlow as I'm trying to write the book on it.
Could this be related?
http://community.m5stack.com/topic/523/problems-with-the-i2c-grove-interface
wow, RFID unit will not work with ENV hat even? I though RFID unit is I2C (G32 and G33) and ENV hat is on G26 and G36...
I could not get them to work together but then i am not a good programmer.
Fellow users from the past, I encountered the same problem but managed to get it working. The problem lies in the paralell access of the RFID and ENV module. If the access is isolated in a paralell process and saved in to variables, further getting the values by using these variables, you should be able to use the two modules in unison.
I use the following code to test:
from m5stack import * from m5ui import * from uiflow import * import i2c_bus setScreenColor(0x111111) devices = None scan = None i2c0 = i2c_bus.easyI2C(i2c_bus.PORTA, 0x68) devices = [] while True: scan = i2c0.scan() if devices != scan: lcd.clear() lcd.print(str(scan), 0, 0, 0xffffff) devices = scan wait_ms(2)I can see the I2C addresses for the Env unit and RFID unit combinations when I plug them into the Grove Hub. I can plug the Env unit in to see addresses 92 and 118, then add RFID unit to see [40, 92, 118] etc.
So I am pretty clueless why the following will fail:
rfid0 = unit.get(unit.RFID, unit.PORTA) env1 = unit.get(unit.ENV, unit.PORTA)Looks like I need to go to the source code and see what's going on...
are modules working ok on their own and you see issue when both connected?
