    Atom Matrix with FW 1.13.1 not connecting to AWS
    13 Posts 2 Posters 9.0k Views
      chr1g1
      It is still not working... Due to the fact that I'm not receiving anything on AWS, I believe it is connected to the networking on the device.
      I see a number of contradicting information and unclear guidance. Here the current approach and questions:
      1/ Internet Mode vs. App Mode. Is MQTT/IOT supposed to work in both modes?
      2/ How I'm supposed to configure networking on the new firmwares? I see the following options:
      wifiCfg.autoConnect(lcdShow=False)
      wifiCfg.reconnect()
      wifiCfg.doConnect('', '')
      wlan.connect('', '')
      3/ Playing with different firmwares because I believe this is buggy.
        Ah I see the Issue now.
        So in Internet mode the WIFI connection is already active because UIFLOW is using it to send and test programs where as in APP mode the WIFI connection is not activated because you haven't opened the connection.
        In App mode you must add the wifi configuration and setup blocks to the code for the Wireless connection to work.
        Sorry, I have been battling a chest infection and so wasn't able to clearly see the solution. While I did write the crappy book on IOT found on amazon, things have changed and I am already writing an update while working on the other deep guides.
          Your setup need to look like this:
            chr1g1
            Still have the problem. I rebuilt the whole program to make sure there are no "old" blocks in there. Don't even see a connection attempt on AWS (IoT Core with enabled debug logging)
            ATOM Matrix
            Firmware: 1.13.2
            Both in Internet and App mode
            -- Code --
            from m5stack import *
            from m5ui import *
            from uiflow import *
            import wifiCfg
            import time
            from IoTcloud.AWS import AWS
            from libs.json_py import *
            import unit
            rgb.set_screen([0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0])
            tvoc_0 = unit.get(unit.TVOC, unit.PORTA)
            CO2 = None
            TVOC = None
            H2 = None
            Ethanol = None
            wifiCfg.doConnect('Guest', 'xxx')
            wait(5)
            aws = AWS(things_name='CO2SENSOR', host='xxx.iot.eu-central-1.amazonaws.com', port=8883, keepalive=500, cert_file_path="/flash/res/certificate.pem.crt", private_key_path="/flash/res/private.pem.key")
            aws.start()
            while True:
            CO2 = tvoc_0.eCO2
            TVOC = tvoc_0.TVOC
            H2 = tvoc_0.H2
            Ethanol = tvoc_0.Ethanol
            aws.publish(str('m5stack/bla'),str((py_2_json({'CO2':CO2,'TVOC':TVOC,'H2':H2,'Ethanol':Ethanol}))))
            print('submitted to AWS')
            wait(5)
            — Serial Log --
            submitted to AWS
            [10490] MQTTException -> [Errno 9] EBADF
            reconnect start ...
            reconnect finish ...
            [14075] MQTTException -> [Errno 9] EBADF
            reconnect start ...
            submitted to AWS
            [17541] MQTTException -> [Errno 9] EBADF
            reconnect start ...
            submitted to AWS
            [20998] MQTTException -> [Errno 9] EBADF
            reconnect start ...
            [24577] MQTTException -> [Errno 9] EBADF
            reconnect start ...
            submitted to AWS
              chr1g1
              Okay - testet the very same code with an MStickC. Runs very smooth without issues. Either there are bugs in the code of the Atom Matrix or the device has just too less resources to handle an external sensor along with an IoT connection.
                Nice work keeping at it. there is one more thing I can think of which is basically a last thing to try.
                Add
                import gc
                to the import code and then at the beginning of the loop add
                gc.collect()
                This forces garbage collection in micropython on each pass emptying the memory on each loop.
                Look up Micropython Garbage collection function for more information on this.
                unfortunately I can't get into my AWS account and so haven't been able to test but it could be that you have genuinely found an issue in the Atom firmware.
                  chr1g1
                  added it as directed above. Still weird behaviour of the Atom Matrix on FW 1.13.2.
                  Here is the log:
                  I print out "submitted to aws" after the publish block in the loop.
                  APIKEY: xxx
                  submitted to aws
                  [17797] MQTTException -> 128
                  reconnect start ...
                  submitted to aws
                  submitted to aws
                  submitted to aws
                  submitted to aws
                  submitted to aws
                    chr1g1
                    okay some more learnings...
                    All S3 devices are supported by UIFlow 2.0 only. And UIFlow 2.0 is not yet supporting AWS IoT unless I missed something.
                    M5StickC Plus is working as a charm. Like M5StickC. I guess I stick with those.
                    My summary as of Feb 2024 and Firmware 1.13.2 and UIFlow 2.0 (Alpha 29):
                    Forget all new devices that are supported by UIFlow 2.0 only (e.g. *S3) and the small ATOMs if you wanna do AWS IoT stuff. Hope you find this before you bought too many devices...
                      chr1g1
                      and for completness here my working setup with M5StickC / Plus
                      Will also followup with AWS details.
                        ajb2k3 @chr1g1
                        @chr1g1 said in Atom Matrix with FW 1.13.1 not connecting to AWS:
                        Here is the log:
                        APIKEY: xxx
                        submitted to aws
                        reconnect start ...
                        submitted to aws
                        submitted to aws
                        submitted to aws
                        submitted to aws
                        submitted to aws
                        Well there is an improvement as you are no longer getting the [24577] MQTTException -> [Errno 9] EBADF
                        Which means the Atom is now working
                        Error 128 means that it tried to subscribe to the AWS topic before the connection was made.
                        If you make a subscribe and a call, according to your log it should be present.
                        add a 5 second delay after the AWS start.
