    AtomDTU NB-IoT
    32 Posts 2 Posters 36.6k Views
      Hello @Felix22
      AT+COPS=1,2,"22801"
        Felix22
        b'AT+CSQ\r\r\n+CSQ: 18,0\r\n\r\nOK\r\n'
        men, i have a signal ?
        b'AT+CSTT="iotsim.melita.io","",""\r\r\nOK\r\n'
        b'AT+CSTT?\r\r\n+CSTT: "iotsim.melita.io","",""\r\n\r\nOK\r\n'
        APN is set correct ?
        b'AT+CGREG?\r\r\n+CGREG: 0,5\r\n\r\nOK\r\n'
        Registered ?
        b'AT+COPS: 1,2,"22801"\r\r\nERROR\r\n'
        b'AT+COPS?\r\r\n+COPS: 0,2,"22801",9\r\n\r\nOK\r\n'
        b'AT+CGACT?\r\r\n+CGACT: 1,0\r\n\r\nOK\r\n'
        If i have a connection, do i become an ip-address ?
        with the command AT+CIFSR
          Hello @Felix22
          it is my understanding that AT+CIFSR returns the local IP address in a TCP or UDP connection. (It's an AT command for compatibility with SIM800.)
          See PDF document SIM7020 Series_TCPIP_Application Note_V1.04 - 6.2 TCP Client Connection. You'll find the link to the PDF here.
          The way I use to set the APN is described in the same TCP/IP PDF - 3.2 APN Manual Configuration.
            Felix22
            Result:
            b'\r\nOK\r\n'
            b'\r\nOK\r\n'
            b'\r\nOK\r\n'
            b'\r\nOK\r\n'
            b'\r\nOK\r\n\r\n+CPIN: READY\r\n'
            b'\r\n+CGREG: 0,5\r\n\r\nOK\r\n'
            b'\r\n+CGCONTRDP: 1,5,"iotsim.melita.io","10.xx.xx.xx.255.255.255.0",,"212.xx.xx.xx","212.xx.xx.xx",,,,,1500\r\n\r\nOK\r\n'
            Im a big step wider... now, i have become my ip address... :-)
            Now i think... MQTT, next step.
              Felix22
              Juhuuuu !!
              It works !
              More Information and the solution will follow...
              @felmue : many thanks
                Hello @Felix22
                I am happy to hear you got it working.
                  Felix22
                  now, i have a new problem.
                  The mqtt broker test.mosquitto.test is working with my Blockly but my own Broker on my Server at home in a Docker container is not available from AtomDTU. But with a Internet Test Tool, it is working ( https://testclient-cloud.mqtt.cool/ )
                  I see no difference...
                  The orange part is working and the tree other is not working
                  • Domainname
                  • IP-Address
                  • Dyndns
                    not working...
                    test.mosquitto.org is working fine.
                    Hello @Felix22
                    hmm, that's a tricky one. Now that your modem gets an IP address; have you tried the official MQTT blocks?
                      Felix22
                      you mean the blocks at "Fortgeschritten" / MQTT ?
                      over there it connects over Wlan/Wifi...
                      Is there a MQTT-Block how i can say the RX and TX pin ?
                        Hello @Felix22
                        no, I meant in UIFlow1 with M5Atom selected. Then it's under Base - DTU - NB-IoT - MQTT. There even is an MQTT example.
                          Felix22
                          this hangs by the "Init NB-IoT DTU" Blockly if you have not Load the Unit NB-IoT.
                          But with the NB-IoT-Unit and the correct RX/TX Pin's it works fine.
                          Do you also use the Atom DTU NB-IoT ?
                            Hello @Felix22
                            not exactly; I use an C-Back NB-loT Global version (SIM7020G) which I connected to an M5Atom the same way it is connected in the AtomDTU NB-IoT.
                            And no, I do not need to add the NB-IoT unit for the Init NB-IoT DTU block to work.
                              Hello @Felix22
                              I have successfully connected, subscribed and published to the following free MQTT brokers: mqtt.m5stack.com, broker.mqtt.cool, test.mosquitto.org, broker.hivemq.com, broker.emqx.io, and public.mqttserver.eu using below UIFlow:
                                Felix22
                                Do you have a list with the Status Codes ?
                                Signal Qualität: 16
                                MQTT-Connection: 0
                                Network-Registration: 7
                                GPRS network registration
                                  Hello @Felix22
                                  sure, here you are:
                                  • Signal Quality: 17
                                  • MQTT-Connection: 0
                                  • Network Registration: 7
                                  • GPRS Network Registration: 5
                                  and when connected to MQTT broker
                                  • MQTT-Connection: 1
                                    Felix22
                                    Hello Felix
                                    By the error code I meant what the individual numbers mean.
                                    Each code 0 to x
                                    Do you have a code list ?
                                    Greeting
                                      Hello @Felix22
                                      no, sorry, I don't have such a list. But if the error code is from an AT command you should be able to find its meaning from the AT command document linked on the product page.
