    AtomDTU NB-IoT
    32 Posts 2 Posters 36.6k Views
      Hello @Felix22
      I am happy to hear you got it working.
        Felix22
        now, i have a new problem.
        The mqtt broker test.mosquitto.test is working with my Blockly but my own Broker on my Server at home in a Docker container is not available from AtomDTU. But with a Internet Test Tool, it is working ( https://testclient-cloud.mqtt.cool/ )
        I see no difference...
        The orange part is working and the tree other is not working
        • Domainname
        • IP-Address
        • Dyndns
          not working...
          test.mosquitto.org is working fine.
          Hello @Felix22
          hmm, that's a tricky one. Now that your modem gets an IP address; have you tried the official MQTT blocks?
            Felix22
            you mean the blocks at "Fortgeschritten" / MQTT ?
            over there it connects over Wlan/Wifi...
            Is there a MQTT-Block how i can say the RX and TX pin ?
              Hello @Felix22
              no, I meant in UIFlow1 with M5Atom selected. Then it's under Base - DTU - NB-IoT - MQTT. There even is an MQTT example.
                Felix22
                this hangs by the "Init NB-IoT DTU" Blockly if you have not Load the Unit NB-IoT.
                But with the NB-IoT-Unit and the correct RX/TX Pin's it works fine.
                Do you also use the Atom DTU NB-IoT ?
                  Hello @Felix22
                  not exactly; I use an C-Back NB-loT Global version (SIM7020G) which I connected to an M5Atom the same way it is connected in the AtomDTU NB-IoT.
                  And no, I do not need to add the NB-IoT unit for the Init NB-IoT DTU block to work.
                    Hello @Felix22
                    I have successfully connected, subscribed and published to the following free MQTT brokers: mqtt.m5stack.com, broker.mqtt.cool, test.mosquitto.org, broker.hivemq.com, broker.emqx.io, and public.mqttserver.eu using below UIFlow:
                      Felix22
                      Do you have a list with the Status Codes ?
                      Signal Qualität: 16
                      MQTT-Connection: 0
                      Network-Registration: 7
                      GPRS network registration
                        Hello @Felix22
                        sure, here you are:
                        • Signal Quality: 17
                        • MQTT-Connection: 0
                        • Network Registration: 7
                        • GPRS Network Registration: 5
                        and when connected to MQTT broker
                        • MQTT-Connection: 1
                          Felix22
                          Hello Felix
                          By the error code I meant what the individual numbers mean.
                          Each code 0 to x
                          Do you have a code list ?
                          Greeting
                            Hello @Felix22
                            no, sorry, I don't have such a list. But if the error code is from an AT command you should be able to find its meaning from the AT command document linked on the product page.
