    195 Posts 79 Posters 570.9k Views 13 Watching
    • W Offline
      Waittherack @Waittherack
      @waittherack said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
      It seems like I can't download my programs anymore, neither in Wifi nor with the USB-C cable. I have a M5Stack Core2. This is what i get both ways : 0_1707839419278_644aa359-ea71-4ef4-a3e3-4ea80718fc6f-image.png 0_1707839440797_7063265d-eb2f-4c59-9f4d-f0b3d6ef1009-image.png
      Can someone explain that to me ? It blocks everything, maybe the answer is within the yellow lines but I don't really know what to do :/
      • robskiR Offline
        robski @Waittherack
        is your device firmware(2.0.0 alpha) matches web UIFlow2 version (current 2.0.1)? if not then update via M5Burner
          crami25 @ajb2k3
          @ajb2k3 ??? Using UIFlow or Python you can have multiple Apps or Programs on your M5Stack device !!
          https://www.hackster.io/AJB2K3/multipage-programs-on-the-m5stack-core2-bc302c
          • B Offline
            BritOnTour
            I have an S3 with UIFLOW2 installed. I cannot get it to connect on the WEB interface of UIFLOW2.0_1709933512731_2024-03-08 15_30_09-.png
            When I click on the device I get the S3 showing with a red dot. Help!
              ajb2k3 @BritOnTour
              @britontour Have you installed the UIFlow2 firmware to the CoreS3 and is the screen of the CoreS3 showing that its connected to the server?
              • B Offline
                BritOnTour @ajb2k3
                @ajb2k3 said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
                This is the info on the S3. UIFLOW2 is loaded, but I notice that it says Private, but my connection in the Web interface is Public.
                • W Offline
                  Waittherack @robski
                  @robski I just did, it seemed to work but it blocks once again. The thing is I have made a little library on this thing which contains lots of images, and I have to reload them one by one after Burning. There are currently probably 60 images in 70x70 to send and some more in other dimensions, and I'm wondering if that could be the problem, just the device not supporting that much, even though that seems unlikely since it doesn't use flash memory or anything...
                  Which leads me to a question ; Is there a way, as there is for .json files, to just use images stored in the SD card directly ? Didn't find a way yet, but it's really long to put back all the images after every new updates :/
                    ajb2k3 @BritOnTour
                    @britontour Private isn't to do with the web connection, it to do with the device status in UIFLow 2.
                    Because the device cant contact the server it can only be used over WebUSB in Chrome.
                    BTW don't show you device MAC.
                    • B Offline
                      BritOnTour @ajb2k3
                      @ajb2k3 OK, if that is not the problem. do you know what could be? Should the user account be something other than none? Do you know what the red X means?
                      What steps should I follow to connect to the server?
                      ajb2k3A dissyD 2 Replies Last reply Reply Quote 0
                        ajb2k3 @BritOnTour
                        @britontour said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
                        The red X just means it was unable to communicate with the default server.
                        • dissyD Offline
                          dissy @BritOnTour
                          @britontour You may wish to completely start over with the pairing process.
                          1. Put your device in programming mode and use m5burner to do an 'erase'
                          2. In uiflow2, click the button to select a device to connect to, and hover the mouse over your device icon. In the top right of that icon (when hovered over) should be a square you can click to edit the device info. In there should be an 'unregister device' button to fully delete it.
                          3. Back in m5burner, reflash uiflow2 to the device and configure for your wifi.
                          Be sure to keep the 'public' switch on this time.
                          When the flash is done, keep the usb cable attached, hit reset on your device to get into the uiflow menu, and open uiflow2 in your browser again.
                          Click the button to select a device. In a few seconds it should show in the 'public' list with a green dot. Be sure to select it here and not under the usb devices list. Unplug the device from USB.
                          You should now be able to turn the device on/off and the device button in uiflow2 will go green/orange to reflect it is paired properly.
                          • W Offline
                            Waittherack
                            Back to my problem, with a potential solution which i need help about ; My dad wondered if, instead of downloading the images inside the Core's memory, we could just use them from the SD card with a block "Execute mpy code", in which i type : "ImageTest.setImage("sd/AutresImages/Start.jpg")", which should set, theorically, Start.jpg as my image, since it's contained in the file "AutresImages" in the sd card, right ?
                            But it doesn't work. No errors or stuff, it just doesn't :/
                            Anyone has an idea ?
                            robskiR dissyD 2 Replies Last reply Reply Quote 0
                            • robskiR Offline
                              robski @Waittherack
                              check this re: size/name/ etc limits
                              sd card image
                              • dissyD Offline
                                dissy @Waittherack
                                @waittherack Make sure to also add an "execute (eg import)" block to with:
                                from hardware import sdcard
                                I also had the FileIO option under Software turned on, but not sure if that's needed just to reference a file by path.
                                • B Offline
                                  BigAl2301
                                  I'm trying to build a multi-character string from keystrokes but the only way I see is with ByteArray. However ByteArrary doesn't hold strings so I used ENCODE and DECODE as shown in this test code. Maybe this is not how encode and decode work?![alt text](0_1710453182467_Screenshot 2024-03-14 at 5.43.07 PM.png image url)0_1710453189687_Screenshot 2024-03-14 at 5.43.56 PM.png
                                  • dissyD Offline
                                    dissy @IAMLIUBO
                                    @iamliubo Feature request for UIFlow 2.0.2 on Cardputer
                                    On the main menu, can the characters on the arrow key buttons also be assigned to perform navigation?
                                    IE so pressing right (Function + arrow) or pressing forward-slash (the same button without holding Function) both navigate right, and the same for left / comma?
                                    It would also be nice to have that functionality in the App.list menu with the up/down arrows (semi-colon and period respectively)
                                    This way screens that only respond to arrow keys can be navigated without having to hold the Function key.
                                    (Note: The new behavior makes perfect sense for screens using both cursor navigation as well as text-input, eg the wifi settings, where holding Function for navigation should remain required)
                                    • B Offline
                                      BritOnTour @BigAl2301
                                      @bigal2301 Use a list instead of bytearray to hold the characters, then use "make text from list" to assign the list of characters to your string variable
                                      • B Offline
                                        BritOnTour @dissy
                                        @dissy said in UiFlow 2.0 discuss(how-to, bug, feature request or sometings):
                                        I'm stuck at step 3. I connect to the device in WebBurner (you say m5Burner, but that doesn't support S3), then click on "Configure" and enter the wifi credentials. When I click Confirm, I get an error message:
                                        Error
                                        Request failed. Check the network and try again!
                                        Looking in the developer tab of Chrome, there is a 404 error attempting to download from https://uiflow2.m5stack.com/m5stack/api/v2/device/downloadBin
                                        Is this a server issue, or a problem with my connection?
                                        • B Offline
                                          BritOnTour @BritOnTour
                                          @britontour I found the m5burner that supports S3. I had an older version for my original Core, and didn't realize there was a new version.
                                          It took a couple of tries, but I managed to bind and reflash the S3. I confirmed that the PUBLIC switch was active before flashing. Once complete, my screen still shows is at a PRIVATE device, and uiflow2 still shows a red dot next to it in the public list. The device info also shows it as PUBLIC. uiflow2 will not connect to it.
                                          dissyD 1 Reply Last reply Reply Quote 0
                                          • dissyD Offline
                                            dissy @BritOnTour
                                            @britontour If m5burner registered the device into uiflow, and it shows having a MAC and Token value (partially masked out), then it should be re-paired properly.
                                            I'm unsure why your device can not connect to the server to report itself online.
                                            I've just verified the process still works (I don't have a core s3 but used a cardputer which is stamp s3 based)
                                            I did just discover a bug in the 2.0.2 "develop" screen. It may be cardputer specific, but it incorrectly displays "private" in both modes. It's just a display bug though, it isn't effecting my connection
