    [SOLVED] GNSS on Core2: BMM150 issue when using M5 events
    3 Posts 2 Posters 2.0k Views
    • U Offline
      UnumDesignum
      I'm developing a program that uses the GPS and the Magnetometer (BMM150) of the GNSS Module.
      It works fine, but as soon as functions such as M5.BtnA.wasPressed(), screen touch or M5.Axp.GetBatVoltage(), the BMM150 communication seems broken.
      I tried with address 0x68 and 0x69 -> same problem.
      I tried running the task on core 1 or core 0 -> same problem.
      DO YOU HAVE AN IDEA OF WHAT I'M DOING WRONG HERE?
      Examples of error displayed on the monitor.
      After M5.Axp.GetBatVoltage() called:
      11:59:50.763 -> E (22261) IMU: P:0 R 68 7C E:263
      After M5.BtnA.wasPressed() called:
      12:00:33.754 -> E (16003) IMU: P:0 R 68 7C E:-1
      12:00:34.119 -> E (16025) IMU: P:0 R 68 03 E:263
      12:00:34.149 -> E (16038) IMU: P:0 R 68 03 E:263
      Source code to reproduce the issue.
      M5Module_GNSS.h is available here: https://github.com/m5stack/M5Module-GNSS/tree/main/src
      #include <M5Core2.h>
      #include <Arduino.h>
      #include <TinyGPS++.h>
      #include <Wire.h>
      #include "M5Module_GNSS.h"
      #define BIM270_SENSOR_ADDR 0x68
      BMI270::BMI270 bmi270;
      #define WATCHDOG_TIMER 2000UL // ms
      #define BATT_CHECK 20000UL // ms - interval to check battery status
      // variables
      uint32_t last_battery_check = 0;
      uint32_t last_json = 0;
      bool isGPS = false;
      // GPS & Magnetometer
      float biasX, biasY, rangeX, rangeY;
      int16_t magX, magY, magZ;
      int16_t minMagX, minMagY, maxMagX, maxMagY;
      // The TinyGPS++ object
      TinyGPSPlus gps;
      // functions
      void gps_task(void *pvParameters);
      void magneto_task(void *pvParameters);
      void updateBatteryLevel (void) {
      float batVoltage = M5.Axp.GetBatVoltage();
      float batPercentage = ( batVoltage < 3.2 ) ? 0 : ( batVoltage - 3.2 ) * 100;
      Serial.printf("Battery %d\n", batPercentage);
      // ------------------------------------------------ SETUP -----------------------------------------------
      magX = 0;
      magY = 0;
      M5.begin(true, true, true, false, kMBusModeOutput);
      M5.Axp.SetLed(0);
      M5.Lcd.begin();
      xTaskCreatePinnedToCore(gps_task,
      "gps_task",
      10000,
      NULL,
      25,
      NULL,
      0); // running on core 0
      xTaskCreatePinnedToCore(magneto_task,
      "magneto_task",
      10000,
      NULL,
      25,
      NULL,
      1); // running on core 0
      return;
      void magneto_task(void *pvParameters) {
      static int data, cpmt = 100;
      Serial.print("MAGNETO TASK STARTS\n");
      Wire.begin(21, 22, 100000);
      bmi270.init(I2C_NUM_0, BIM270_SENSOR_ADDR);
      while (1) {
      // DEBUG
      cpmt++;
      if ( cpmt > 100 ) {
      Serial.print("•");
      cpmt = 0;
      // Get Magnetometer data
      if (bmi270.magneticFieldAvailable()) {
      bmi270.readMagneticField(magX, magY, magZ);
      if (cpmt ==0) Serial.printf("x %d y %d\n", magX, magY);
      delay(10);
      void gps_task(void *pvParameters) {
      Serial.print("GPS TASK STARTS\n");
      Serial2.begin(38400, SERIAL_8N1, 13, 14);
      while (1) {
      // DEBUG
      cpmt++;
      if ( cpmt > 100 ) {
      Serial.print("+");
      cpmt = 0;
      // Get GPS data
      while (Serial2.available() > 0) {
      data = Serial2.read();
      //Serial.printf("%c", data);
      gps.encode(data);
      isGPS = gps.location.isValid();
      delay(10);
      // ------------------------------------------------ LOOP -----------------------------------------------
      static char text[256];
      static uint32_t msecs;
      M5.update();
      msecs = millis();
      // WATCHDOG
      if ((msecs - last_json) > WATCHDOG_TIMER) {
      if (isGPS) sprintf(text, "GPS %d - ", gps.satellites.value());
      else sprintf(text, "Sat %d - ", gps.satellites.value());
      Serial.println(text);
      last_json = msecs;
      // battery timer
      if ((msecs - last_battery_check) > BATT_CHECK) {
      updateBatteryLevel();
      last_battery_check = msecs;
      if (M5.BtnA.wasPressed()) {
      Serial.println("BtnA pressed");
      if (M5.BtnB.wasPressed()) {
      Serial.println("BtnB pressed");
      if (M5.BtnC.wasPressed()) {
      return;
        Hello @UnumDesignum
        the issue is probably that the internal I2C of M5Core2 library uses Wire1 (and not Wire). See here.
        In your magneto_task you initialize Wire with the same GPIOs (21, 22) so you end up with two I2C instances (Wire and Wire1) fighting for the same GPIOs.
        Try the following and see if that helps:
        //Wire.begin(21, 22, 100000);
        //bmi270.init(I2C_NUM_0, BIM270_SENSOR_ADDR);
        bmi270.init(I2C_NUM_1, BIM270_SENSOR_ADDR);
        U 1 Reply Last reply Reply Quote 0
        • U Offline
          UnumDesignum @felmue
          @felmue A million thanks!
          This was my issue. Your solution works like a charm.
          Thank you!
