    CoreMP135 Debian image
    46 Posts 8 Posters 56.6k Views 4 Watching
      aradke @ajb2k3
      @ajb2k3 sudo isn't included on a minimal Debian installation. It's usually the very first things that we install so that the rest of the system can be fully configured by Ansible.
        aradke @ajb2k3
        @ajb2k3 if you are building the base filesystem inside a chroot environment then you should be able to install packages as normal via apt.
        The permissions from the original source should be fine, and apt will make sure any further permissions are also correct. Going back to fix already damaged permissions would be difficult and it would be very easy to miss something.
          ajb2k3 @aradke
          @aradke said in CoreMP135 Debian image:
          That's why I spent last night going through the source so I could find where these are set. I could not find the config for the directory like /etc.
          Ah it's the host system that set the file permissions.
          When the image was generated it wasn't compiled under root so directorys weren't set as root but to the permissions of the host.
          The image need to be re generated as root.
            aradke @ajb2k3
            @ajb2k3 :-)
            When creating Linux container templates the same issue can arise. If you do any part of it as a non-root account the file and directory ownerships will all end up being the same as the UID you are currently working with instead of as root, etc.
            Sometimes things will appear to function okay for a while but if a directory is meant to be owned by a non-root account, such as www-data, then anything using it will completely fail.
            Is there any chance you'll be able to document the procedure for creating the image? It would be very, very good to be able to create customised ones and to test different kernels.
              ajb2k3 @aradke
              @aradke that’s what I’m doing at the moment. I am taking to the programmer about how to build the image
                prima @ajb2k3
                I am currently writing an Ansible playbook to automate the customization of my device, and some things like setting the time zone don't work for the reason described above. Hopefully this can get fixed soon.
                I am also working on the LCD screen, as I would prefer to use Python rather than the proposed C environment.
                  ajb2k3 @prima
                  @prima well currently I'm trying to get the code to compile following the online instructions but they dont work
                    ajb2k3 @ajb2k3
                    Ah ha I got it to compile, the instructions are wrong.
                    You need to run
                    make BR2_EXTERNAL=../CoreMP135_buildroot-external-st/ m5stack_coremp135_515_defconfig
                    make -j4
                    To get it to compile.
                    I'm Using a CM4Stack so its slow going.
                    The issue turns out to be a typo in the line. The guide says /Core135_ but the command is actually CoreMP135
                      prima
                      On a side note and not sure this is a related issue, but I can't seem to shut down the device cleanly. I have tried: shutdown, poweroff, halt and the device always reboots instead of shutting down.
                        ajb2k3 @prima
                        @prima yeh I noticed that too after issuing the Shutdown now command.
                        • N Offline
                          nnn @ajb2k3
                          A script to build Debian image is now available in the M5Stack repository.
                          • CoreMP135_buildroot-external-st
                            https://github.com/m5stack/CoreMP135_buildroot-external-st/blob/st/2023.02.10/tools/creat_coremp135_debian12_image.sh
                          • How to implement (Japanese)
                            https://qiita.com/nnn112358/items/44921e2470353653058e
                          ajb2k3A M 2 Replies Last reply Reply Quote 0
                            ajb2k3 @nnn
                            @nnn said in CoreMP135 Debian image:
                            Nice
                              mgrouch @nnn
                              @nnn
                              Is there Debian image for CoreMP135 which includes kernel built with all drivers for hardware interfaces of CoreMP135.
                              I’m considering buying that CoreMP135 and
                              I need to make sure I will be able to use CAN Bus interfaces, i2c, uart, USB, Bluetooth, RS485, Both Ethernets and WiFi, as well as
                              touchscreen of CoreMP135 with the Debian image provided.
                              When it boots, does it boot into some kind of framebuffer LVGL GUI on 2” touchscreen?
                              Is there code example how to do that?
                              Or CoreMP135 is sold as hardware platform and users are left to build own Linux kernel and Debian images to support hardware CoreMP135?
                              Or there is a Debian image which fully supports
                              CoreMP135 Hardware and all interfaces?
                              Hardware is not much of use for me if there is no software with drivers supporting it.
                              Thanks!
                              P teastainT 2 Replies Last reply Reply Quote 0
                                prima @mgrouch
                                @mgrouch said in CoreMP135 Debian image:
                                AFAIK there is no wifi/BT on this device. Dual ethernet works using the available Debian image though. That image has some defects but I guess this is being sorted out.
                                You can now build your own image (see post above) but I haven't tried that yet.
                                • I have not tried the CAN bus and the other interfaces.
                                • USB: seems to work, but I only plugged in a mouse and keyboard
                                • The serial console works over USB-C and I also use the USB-C cable to power the device from my PC.
                                If that can help: I recently posted on how to develop Python apps in GTK or QT, using the frame buffer with Xorg/Openbox.
                                This is roughly the approach I have used for developing on Raspberry PI and other SBCs.
                                The touch screen work without problem for me.
                                • teastainT Offline
                                  teastain @mgrouch
                                  @mgrouch https://github.com/m5stack/M5Stack_Linux_Libs
                                  The Official M5Stack CoreMP135 library repository.
                                    mgrouch @prima
                                    @prima said in CoreMP135 Debian image:
                                    Ok. No wifi or bt is not an issue for me as long as Ethernet works.
                                    Is it working as DHCP client? I mean it’s just plug into router and I could ssh?
                                    I do care about working CAN, i2c, UART, and RS-485 out of the box with provided Debian image.
                                    Does anyone have experiences with those interfaces on CoreMP135 with their provided OS image?
                                      ajb2k3 @mgrouch
                                      @mgrouch yes but you will need to access the coreMP135 directly to find the initial IP address. I have been working on documentation but been busy since I started work on making the image compilation steps.
                                        mgrouch @ajb2k3
                                        @ajb2k3 said in CoreMP135 Debian image:
                                        Documentation is definitely lacking steps on
                                        using CAN, i2c, uart, RS-485 on coremp135
                                        What is Linux kernel version on Debian image?
                                          ajb2k3 @mgrouch
                                          @mgrouch bookworm
                                            prima @ajb2k3
                                            The mDNS service aka Zeroconf aka Avahi aka Bonjour is already enabled on the device, so if you have the client tools installed on your PC you can connect in SSH using the .local address like this:
                                            ssh root@M5Core135.local
                                            M5Core135 is the default hostname.
