    MQTT UIFlow problems
    19 Posts 5 Posters 40.4k Views 2 Watching
      dvd78
      yesterday i downloaded my first blocky with mqtt and it was running. Today i tryed to reload (download from M5Flow) the same blocky but it's no more running. Nothing has been changed in my code, but i saw a new UI of Flow, is it possible that the new "http://flow.m5stack.com/" has some problems?
        heybin
        Very sorry, we will fix it today,
        D world101W 2 Replies Last reply Reply Quote 0
          dvd78 @heybin
          @heybin thank you, this evening i will try...
          also, if i can, i think then the image used to insert text, label etc...in the m5 is too little
          • world101W Offline
            world101 @heybin
            @heybin said in MQTT UIFlow problems:
            Has it been fixed yet? I'm trying the example, but after downloading the MQTT example flow to my m5stack Fire, it just freezes. It is not responsive until I reset it.
            https://m5stack.github.io/UIFlow_doc/cn/zh_CN/MQTT/Example.html
            My flow:
            cloudmqtt settings:
            Here are the logs from cloudmqtt.com. Not sure how to resolve the socket error.
            2019-01-22 19:07:18: mosquitto version 1.5.5 starting
            2019-01-22 19:07:18: Config loaded from /var/lib/mosquitto/19639/mosquitto.conf.
            2019-01-22 19:07:18: Opening ipv4 listen socket on port 29639.
            2019-01-22 19:07:18: Opening websockets listen socket on port 39639.
            2019-01-22 19:07:18: Opening ipv4 listen socket on port 19639.
            2019-01-22 19:09:09: New client connected from 64.100.78.39 as cloudmqtt-st-ui-0.9613626986254669 (c1, k60, u'oklhhzzb').
            2019-01-22 19:09:10: Socket error on client cloudmqtt-st-ui-0.9613626986254669, disconnecting.
            2019-01-22 19:09:11: New client connected from 64.100.78.39 as cloudmqtt-ws-ui-0.6445892594600325 (c1, k60, u'oklhhzzb').
            2019-01-22 19:10:05: Client cloudmqtt-ws-ui-0.6445892594600325 disconnected.
              What Operating system do you use?
              What M5 are you using?
                ajb2k3 @dvd78
                @dvd78 said in MQTT UIFlow problems:
                Use the internet browsers zoom function.
                • world101W Offline
                  world101 @ajb2k3
                  @ajb2k3 said in MQTT UIFlow problems:
                  I'm on a Mac with OS 10.13.6 (High Sierra).
                  I have the m5stack Fire (red) hardware running v1.1.1.
                  Is MQTT working for you?
                    ajb2k3 @world101
                    @world101
                    Yes, but I'm worried about the restarting.
                    I only have an M5Core
                    • world101W Offline
                      world101 @ajb2k3
                      I have a m5stack grey as well that I will try tonight.
                        dvd78
                        i have an M5core too but mqtt is not working yet
                          ajb2k3 @dvd78
                          @dvd78 Update firmware to 1.1.1 to get MQTT working.
                            dvd78 @ajb2k3
                            i did it yesterday, do i need to download a new version?
                              heybin
                              @dvd78 Sorry, yesterday our engineers forgot to update....
                              now, already fixed, refresh web page it will be ok
                              world101W D 2 Replies Last reply Reply Quote 0
                              • world101W Offline
                                world101 @heybin
                                @heybin
                                MQTT working good for me now with both of my grey and fire m5stack cores. I have tested cloudmqtt and io.adafruit. Thanks for fixing it!
                                  dvd78 @heybin
                                  @heybin thank you, problem is solved.
                                  bye
                                    The_Stacker
                                    I tried the same blocky today. It uploaded but on the display I only see: error ImportError('mqtt need download...'.)
                                    I am using an M5Stack Fire, firmware 1.1.2.
                                    I have a local MQTT broker running on an Onio Omega and the upload is done with a Windows 10 computer.
                                    Any help would be appreciated.
                                    • world101W Offline
                                      world101 @The_Stacker
                                      @the_stacker
                                      Instead of running the program directly from uiFlow (which is the triangle button at the top-right), just click the Download option from the hamburger menu.
                                        The_Stacker
                                        Thanks! That worked.
                                        Just out of curiosity: What's the difference between the two?
                                        • world101W Offline
                                          @the_stacker said in MQTT UIFlow problems:
                                          Run is just for quick testing of your program. It is erased on a reboot. Download will add the program to the flash storage on the device so you can access it from the APP.LIST menu (middle button when the M5stack is booting up - inbeteeen upload and setup).
