    M5Stack - Simple Applications Menu + some APPs
    40 Posts 10 Posters 244.7k Views 6 Watching
    • SunWukongS Offline
      SunWukong
        SunWukong
        Hi @TomSuch , I like your SAM, have cloned it and extend it a bit.
        I have add an APP - appBME280, to read a Grove - Barometer Sensor.
        M5Stack-SAM ext. version
        appBME280
        T W 3 Replies Last reply Reply Quote 3
          TomSuch @SunWukong
          @sunwukong Super, good work. Thank you
          SunWukongS 1 Reply Last reply Reply Quote 1
            TomSuch
            Added QR-Code APP
              TomSuch
              Added Serial Interface for remote control:
              Serial control at 115200 8N1 and NL&CR termination
              bright [0-255] - display bright
              EXAMPLE: bright 128
              clr - clear display
              sleep - power sleep, wakeup on BTN_B
              qrc [text] - show QRCODE with text
              EXAMPLE: qrc www.google.com
              Send iBeacone message
              ibeacon [major code 0-65535] [minor code 0-65535] [power 0-255]
              EXAMPLE: ibeacon 1024 2048 50
              Send Eddystone TLM message
              eddystonetlm [voltage 0-65535] [temperature 0-65535] [pocket cound 0-4294967295] [second from up 0-4294967295]
              EXAMPLE: eddystonetlm 100 200 300 400
              Send Eddystone URL message
              eddystoneurl [prefix 0-3] [power 0-255] [url]
              EXAMPLE: eddystoneurl 1 1 google.com
              PREFIXES:
              0 http://www.
              1 https://www.
              2 http://
              3 https://
                TomSuch @JJ
                @jimit Thank you for the positive bond ...
                • JJJ Offline
                  JJ @TomSuch
                  @tomsuch
                  No problem Tom. Very much deserved !
                  Have got a wifi scan working with this under the Apps menu... but need to more spend a bit more time to get the screen output layout right... so each scan displays from the same line each time.
                  • m5stackM Offline
                    Awesome, i think we should do some offical support about this good idea.
                    T 1 Reply Last reply Reply Quote 3
                      TomSuch @m5stack
                      @m5stack Thank you. I'd like to create something like a Swiss knife for makers.I like M5Stack and I'd like to create applications like a simple pocket oscilloscope, multimeter, I2C / SPI sniffer, signal generator, and so on. I think M5Stack is a platform with a lot of potential. Regards..
                        TomSuch
                        New version:
                        Added:
                        • APP - GY-512 (MPU6050) - gyro/accelerometer
                        • APP - variable speed Serial PASS-THRU USB<->UART2
                        • SYSTEM - System Informatins (CPU Speed, Flash Size, Flash SPEED, SDK Version .......)
                        • Serial Commands - WiFiScan, I2CScan
                        • m5stackM Offline
                          @TomSuch I got your mind, and similar to me, i really hope it like a swiss knife. useful and meaningful.
                            Kryten
                            I get errors on all
                            [code]
                            #pragma mark
                            [/code]
                            Will comment out and try again
                              TomSuch @Kryten
                              @kryten Please specify the error. Arduino version. Take PrintScreen.
                              Do you have installed M5.libraries ? ESP32 libraries ?
                              • reaper7R Offline
                                reaper7
                                @tomsuch 在 M5Stack - Simple Applications Menu + some APPs 中说:
                                APP - GY-512
                                very nice system!
                                APP - GY-512 works also with built-in MPU9250 :)
                                Can You modify TIM MEASUREMENT APP?
                                S/S button should 1.START->2.STOP->3.START without reset between 2 and 3 step...(something like continous measurement with pause). For reset value we have RES button
                                  TomSuch @reaper7
                                  @reaper7 Hi, thanks for the subject. I edited the application of the stopwatch and is already out. Regards...
                                  • JJJ Offline
                                    JJ
                                    T 2 Replies Last reply Reply Quote 0
                                      TomSuch @JJ
                                      @jimit Hi, good work. But I did not find the code on your git ...
                                      • JJJ Offline
                                        JJ @TomSuch
                                        @tomsuch
                                        Oops... sorry bout that. Have added them now....
                                          TomSuch @JJ
                                          @jimit OK, I'm going to check it out ..
                                            TomSuch @JJ
                                            @jimit Hello Jimi, I have redesigned your WiFi scanner application and there is a new version M5Stack-SAM with this APP out there.
                                            https://github.com/tomsuch/M5Stack-SAM
