    M5Stack - Simple Applications Menu + some APPs
    40 Posts 10 Posters 244.7k Views 6 Watching
      TomSuch @SunWukong
      @sunwukong Super, good work. Thank you
      SunWukongS 1 Reply Last reply Reply Quote 1
        TomSuch
        Added QR-Code APP
          TomSuch
          Added Serial Interface for remote control:
          Serial control at 115200 8N1 and NL&CR termination
          bright [0-255] - display bright
          EXAMPLE: bright 128
          clr - clear display
          sleep - power sleep, wakeup on BTN_B
          qrc [text] - show QRCODE with text
          EXAMPLE: qrc www.google.com
          Send iBeacone message
          ibeacon [major code 0-65535] [minor code 0-65535] [power 0-255]
          EXAMPLE: ibeacon 1024 2048 50
          Send Eddystone TLM message
          eddystonetlm [voltage 0-65535] [temperature 0-65535] [pocket cound 0-4294967295] [second from up 0-4294967295]
          EXAMPLE: eddystonetlm 100 200 300 400
          Send Eddystone URL message
          eddystoneurl [prefix 0-3] [power 0-255] [url]
          EXAMPLE: eddystoneurl 1 1 google.com
          PREFIXES:
          0 http://www.
          1 https://www.
          2 http://
          3 https://
            TomSuch @JJ
            @jimit Thank you for the positive bond ...
            • JJJ Offline
              JJ @TomSuch
              @tomsuch
              No problem Tom. Very much deserved !
              Have got a wifi scan working with this under the Apps menu... but need to more spend a bit more time to get the screen output layout right... so each scan displays from the same line each time.
              • m5stackM Offline
                Awesome, i think we should do some offical support about this good idea.
                T 1 Reply Last reply Reply Quote 3
                  TomSuch @m5stack
                  @m5stack Thank you. I'd like to create something like a Swiss knife for makers.I like M5Stack and I'd like to create applications like a simple pocket oscilloscope, multimeter, I2C / SPI sniffer, signal generator, and so on. I think M5Stack is a platform with a lot of potential. Regards..
                    TomSuch
                    New version:
                    Added:
                    • APP - GY-512 (MPU6050) - gyro/accelerometer
                    • APP - variable speed Serial PASS-THRU USB<->UART2
                    • SYSTEM - System Informatins (CPU Speed, Flash Size, Flash SPEED, SDK Version .......)
                    • Serial Commands - WiFiScan, I2CScan
                    • m5stackM Offline
                      @TomSuch I got your mind, and similar to me, i really hope it like a swiss knife. useful and meaningful.
                        Kryten
                        I get errors on all
                        [code]
                        #pragma mark
                        [/code]
                        Will comment out and try again
                          TomSuch @Kryten
                          @kryten Please specify the error. Arduino version. Take PrintScreen.
                          Do you have installed M5.libraries ? ESP32 libraries ?
                          • reaper7R Offline
                            reaper7
                            @tomsuch 在 M5Stack - Simple Applications Menu + some APPs 中说:
                            APP - GY-512
                            very nice system!
                            APP - GY-512 works also with built-in MPU9250 :)
                            Can You modify TIM MEASUREMENT APP?
                            S/S button should 1.START->2.STOP->3.START without reset between 2 and 3 step...(something like continous measurement with pause). For reset value we have RES button
                              TomSuch @reaper7
                              @reaper7 Hi, thanks for the subject. I edited the application of the stopwatch and is already out. Regards...
                              • JJJ Offline
                                JJ
                                T 2 Replies Last reply Reply Quote 0
                                  TomSuch @JJ
                                  @jimit Hi, good work. But I did not find the code on your git ...
                                  • JJJ Offline
                                    JJ @TomSuch
                                    @tomsuch
                                    Oops... sorry bout that. Have added them now....
                                      TomSuch @JJ
                                      @jimit OK, I'm going to check it out ..
                                        TomSuch @JJ
                                        @jimit Hello Jimi, I have redesigned your WiFi scanner application and there is a new version M5Stack-SAM with this APP out there.
                                        https://github.com/tomsuch/M5Stack-SAM
                                        • JJJ Offline
                                          JJ @TomSuch
                                          @tomsuch Thanks Tom... looks much better ! One thing - for me once the scan is done it lists the networks but the screen refreshes immediately before they can be read.... tested on two different M5s ? Strange if it's not happening for you too. Hate to respond with a negative when you've done such nice work. BTW, the system info page you added is great to have and the others too. Awesome work.
                                            TomSuch @JJ
                                            @jimit Hi Jim, I think I found and remove the bug. Can you try a new, fixed version? Thank you...
                                            https://github.com/tomsuch/M5Stack-SAM/
