    Error Request failed. Check the network and try again!
    12 Posts 8 Posters 7.9k Views 1 Watching
      felmue @mattjcuk
      Hi guys
      same error here when I try to save my UIFlow2 blocks.
      @m5stack please fix.
        ankurjana
        Same issue, its definitely some cloud connection problem
        • Xio1996X Offline
          Xio1996
          Just tried it this morning and it all works again.
          Thank you for fixing the problem.
          I was just being silly with my USB problem. It helps if I click on the USB device, doh!
            ajb2k3 @Xio1996
            @Xio1996 ROFL!
            I’ve been busy so wasn’t able to check on the server but because UIFlow uses Micropython, devices can be programmed offline using IDE’s like Thonny and Mu!
              makingautomation
              Hi Guys
              I'm still having this issue and have been since yesterday.
              Does anyone have a solution for this or is it an M5 server related issue?
                felmue @makingautomation
                Hi guys
                for me it comes and goes. Sometimes it works, sometimes it fails.
                BTW: browser console reports an 'internal server error' - so it's most likely a server side issue.
                  rfok
                  Hello!
                  Same issue foe me
                    mattjcuk @felmue
                    It was working first thing this morning but not now.
                    Thanks,
                    Matthew
                      mattjcuk @mattjcuk
                      Seems to be back
                        SveinHa @mattjcuk
                        Started with UIFlow 2.0/M5Paper today and just when I got things to work, I got network error. Unable to transfer program using USB also... or the USB seems to work but the program transferred is an old version... Restarted my PC end lost quite a bit but still "Check network..."...
