    ISO RS485 on M5dial
    11 Posts 3 Posters 7.3k Views
      mukul_100_
      Hi, So i have a ISO RS485 and i need to get modbus working on it. The primary problem im facing is that the module is UART based and by my understanding M5Dial has I2C and GPIO ports. Is it as simple as hardware serial and setting 1 and 2 pins to UART or is there something else to it
      Also it would be great help if there are any modbus library that can be used.
      Thank You
      • robskiR Offline
        robski @mukul_100_
        @mukul_100_ what software you planning to use?
        see uiflow2 init example
          mukul_100_ @robski
          i am using platformio right now. thanks
          • felmueF Online
            felmue @mukul_100_
            Hello @mukul_100_
            please find an example here with M5Dial and RS485 unit controlling an ACSSR relay via Modbus protocol.
              mukul_100_ @felmue
              @felmue hi felix sorry for the late reply, finally got a chance to get back to this
              i studied the example but not sure if i understood how to implement the master slave concept through this and also there is a error thrown in
              RS485Class RS485(Serial2, GPIO_NUM_1, GPIO_NUM_2, -1, -1);
              as there are only 4 arguments accepted by the class
              also serial2 needs some tweaking for esp32 right?
              thanks
              • felmueF Online
                felmue @mukul_100_
                Hello @mukul_100_
                I linked the incorrect variants for RS485 and Modbus libraries. Sorry about that. I fixed the example. The libraries I used are the ones from M5Stack.
                https://github.com/m5stack/ArduinoModbus
                https://github.com/m5stack/ArduinoRS485
                  mukul_100_ @felmue
                  @felmue Hi felix
                  the changes you mentioned are in the same example code that is linked above?
                  • felmueF Online
                    felmue @mukul_100_
                    Hello @mukul_100_
                    yes.
                      mukul_100_ @felmue
                      @felmue ,did you make any changes in the RS485.h file
                      along these line 46
                      #else
                      #ifndef RS485_DEFAULT_DE_PIN
                      #define RS485_DEFAULT_DE_PIN A6
                      #define RS485_DEFAULT_RE_PIN A5
                      #endif
                      thanks,
                      Mukul
                      • felmueF Online
                        felmue @mukul_100_
                        Hello @mukul_100_
                        No.
                        I think you are still on the library I incorrectly linked to in my example before.
                        Incorrect library: https://github.com/**arduino-libraries**/ArduinoRS485
                        Library I used: https://github.com/**m5stack**/ArduinoRS485
                          mukul_100_ @felmue
                          @felmue Hi, felix i got it working finally. The issue is, on platformIO the library Arduinomodbus library and ArduinoRS485 library are the arduino ones and not the m5stack ones which is why i was getting error.
                          A fix to this was to just replace the internal files of library to the m5stack ones from github.
                          Thank you for the help.
