    Problems with the Labels
    16 Posts 4 Posters 32.9k Views 1 Watching
      heybin
      I have met this, but I don’t know how to reproduce it,Can you describe how to trigger?
      ajb2k3A G 2 Replies Last reply Reply Quote 0
        ajb2k3 @heybin
        @heybin said in Problems with the Labels:
        Will see If I reproduce the steps I took to cause the bug later.
          I have added a few extra font changes to trigger the bug but its the first set font that is triggering "Font not defined."
          alt text
          UIFlow and firmware 1.1.1
            heybin
            this bug will fix in those day, but gadjet said looks like another bug...
              The ghosting, i think, is to do with the lcd screen,
              I made guess that he was using the deja vue and trying to set it with the different size specific block.
              • G Offline
                gadjet @ajb2k3
                @ajb2k3 said in Problems with the Labels:
                I did some more work and found the ghosting is when I modify a label, when I leave the label and then use LCD.Print to add the text is seems to be OK.
                I was mistakenly using the label object to write a changing value to the screen, LCD.print works OK but editing the label would still give the ghosting issue.
                • G Offline
                  gadjet @heybin
                  I have a suspicion that it happens after the code has been downloaded and you try to edit the labels, a reload of the page and the project fixes it.
                  I will test out my theory tonight and feedback.
                  • world101W Offline
                    world101 @gadjet
                    @gadjet said in Problems with the Labels:
                    Where is LCD.print in UIFlow? Is it the print block under the Text menu?
                      ajb2k3 @world101
                      @world101 lcd.print is a micropython command, you use the Label show block which is the first block I put under the setup bock in the screen grab I posted above.
                      • G Offline
                        gadjet @world101
                        @world101 It's in the "Graphic" group
                        ![LCD.Print](image url)
