    Can't read ENV IV using UIFlow2
    4 Posts 4 Posters 2.4k Views
    • G Offline
      guarthur
      I can't get my M5Stickplus2 to read any variables from my ENV IV. I've used the example and it doesn't work. Does anyone has a valid example that works? I'm wondering whether the ENVIV has a problem
      robskiR R 2 Replies Last reply Reply Quote 0
      • robskiR Offline
        robski @guarthur
        @guarthur said in Can't read ENV IV using UIFlow2:
        have you tried EasyLoader file for ENV 4 unit?
        have you tried Arduino example from ENV 4 documentation page? - Double check that I2C pins are correct
          RBOUMAN58 @guarthur
          @guarthur
          Just try these module in uiflow1
          I have core-2 ,m5stickC and m5stickC Plus and an external IMU and a env PRO module
          Used them all with the same blocks in uiflow2 and uiflow1, Core-2 no problems at all.
          The sticks only work with these sensors in iuflow1.
          using the sticks with uiflow2 gives an i2c error (during uploading a red line flashes fast in a window) and the modules are not found, doing i2cscan returns an empty list.
          in uiflow 1 the modules work and i2cscan gives the correct i2c adresses
          M5stack makes beautiful hardware and shitty software. Thinking now of throwing all these junk just in the electronic recycle bin.
          • kurikoK Offline
            kuriko @RBOUMAN58
            @RBOUMAN58
            What version of UiFlow firmware do you have on StickC? As far as I know, the latest version of the firmware sometimes buggy, and the problem of not being able to scan I2C devices has occurred before. Maybe rollback to the old version will help.
