    m5stick c plus 2 not turning on
    Scheduled Pinned Locked Moved ESP - IDF
    5 Posts 5 Posters 6.7k Views
      cmcrrr
      recently i bought an m5stick c plus 2 and i downloaded nemo
      it was working normally but 2 days later my stick wasnt booting
      when i hold the on/off button appears an green light but the screen doesnt turn on
      when i try to burn something in the m5burner this is what happens:
      Detecting chip type...
      ESP32
      Chip is ESP32-PICO-V3-02 (revision v3.0)
      Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, Embedded PSRAM, VRef calibration in efuse, Coding Scheme None
      Crystal is 40MHz
      MAC: e8:9f:6d:32:e2:58
      Uploading stub...
      Running stub...
      Stub running...
      Changing baud rate to 1500000
      Changed.
      WARNING: Failed to communicate with the flash chip, read/write operations will fail. Try checking the chip connections or removing any other hardware connected to IOs.
      Configuring flash size...
      Warning: Could not auto-detect Flash size (FlashID=0xffffff, SizeID=0xff), defaulting to 4MB
      Flash will be erased from 0x00000000 to 0x00289fff...
      Compressed 2660976 bytes to 1589191...
      A fatal error occurred: Packet content transfer stopped (received 8 bytes)
      help pls
      teastainT robskiR 2 Replies Last reply Reply Quote 0
      • teastainT Offline
        teastain @cmcrrr
        @cmcrrr Maybe the Nemo hacking software hacked you?
        This happens so often I am starting to suspect that Nemo has itself been hacked.
        You should contact the wider Nemo hacking community. and see any fellow hackers are experience this problem.
        • robskiR Offline
          robski @cmcrrr
          @cmcrrr can you try to use M5Burner and go for ERASE before burn? Or just try to load EasyLoader file for M5Stack? or just load siple sketch from Arduino?
            felmue @robski
            Hello @cmcrrr
            you might want to force M5StickCPlus2 into download mode manually. Below are the steps:
            1. disconnect USB
            2. press and hold PWR button until green LED lights up, then release button
            3. connect a wire from G0 to GND
            4. attach USB
            5. press and hold PWR button until green LED lights up, then release button
            6. remove wire
              --> M5StickCPlus2 is now in download mode.
            7. Use M5Burner to erase or flash something.
            • E Offline
              eugenHypr @felmue
              @felmue what do you mean "connect wire from G0 to GND"?
