    M5Dial TFT_eSPI pinout
    17 Posts 5 Posters 17.1k Views 1 Watching
    • gordshG Offline
      gordsh
      @ajb2k3 said in M5Dial TFT_eSPI pinout:
      GC9A01 driver
      Hmm, no I did not. Let me do some research and try to find the driver
      • gordshG Offline
        gordsh
        Can any one get this simple GC9A01 test to run on the M5Dial
        • https://github.com/carlfriess/GC9A01_demo
        My goal is to have LVGL running on the M5Dial so I am working my way through the display issues at this time.
          This is the Micropython code I used to get a basic "Hello World" working.
          import os, sys, io
          import M5
          from M5 import *
          label0 = None
          def setup():
            global label0
            M5.begin()
            label0 = Widgets.Label("label", 50, 100, 1.0, 0xffffff, 0x222222, Widgets.FONTS.DejaVu18)
            label0.setCursor(x=50, y=100)
            label0.setText(str('Hello World'))
            label0.setVisible(True)
          def loop():
            global label0
            M5.update()
          if __name__ == '__main__':
            try:
              setup()
              while True:
                loop()
              try:
                print_error_msg(e)
              except ImportError:
                print("please update to latest firmware”)
          • gordshG Offline
            gordsh
            M5
            Thank you.
              Hello @gordsh
              re TFT_eSPI : try adding the following define in Setup200_GC9A01.h
              #define TFT_BACKLIGHT_ON HIGH
              re GC9A01_demo : please find an M5Dial version here.
              • gordshG Offline
                gordsh
                @felmue, thanks very much, This worked perfectly.
                  mukul_100_ @gordsh
                  @gordsh Hi ,
                  did you get this working ?
                  I am banging my head against the wall with this one right now ,
                  I am trying to use EEZ Studio with M5dial and using platform.io (or arduino ide whichever works)
                  also if you have the file of user_setup.h for GC9A01. kindly share
                  Thank You
                    mukul_100_ @mukul_100_
                    @mukul_100_ Got this workking by using m5unified instead of tft_espi
                    But i can get the touch to work
                    as per what i read lvgl uses polling to get the touch coordinates using lv_timer_handler();
                    but i dont understand how to implement M5Dial.Touch.getDetail(); to get the touch
                    gordshG 2 Replies Last reply Reply Quote 0
                    • gordshG Offline
                      gordsh @mukul_100_
                      @mukul_100_ I did get this working, I am having a different issue now but I will send you a small demo program that I wrote using LVGL with touch.
                      • gordshG Offline
                        gordsh @mukul_100_
                        @mukul_100_ Here is a small demo of the M5Dial with touch and LVGL. Hope this helps and sorry for the delay.
                        M5DialLVGLTouchDemo.ino
                        M gordshG S 3 Replies Last reply Reply Quote 0
                          mukul_100_ @gordsh
                          @gordsh Oh great thanks a lot, I actually got it working,
                          and after seeing your code i tried to implement the button part with encoder but the dial seems to crash repeatedly because of it. For now that is not my focus so i will try it again later.
                          Also , do you have any idea how the implementation of encoder is eez studio is.
                          i understood that the group is to be made but didnt quite understand how to append/impelment the encoder events to it
                          If anyone has any idea or reference, Thank you in advance.
                          also this is the code for how i implemented the button press with encoder
                          // Encoder read function
                          void encoder_read(lv_indev_drv_t *drv, lv_indev_data_t *data) {
                              long newPosition = M5Dial.Encoder.read() / 4; // Normalize encoder position
                              if (newPosition != oldPosition) {
                                  int encoderDiff = newPosition - oldPosition;
                                  oldPosition = newPosition;
                                  // React to encoder rotation
                                  if (encoderDiff > 0) {
                                      lv_group_focus_next(group);
                                  } else if (encoderDiff < 0) {
                                      lv_group_focus_prev(group);
                              // Check button press
                              if (M5Dial.BtnA.wasPressed()) {
                                  data->state = LV_INDEV_STATE_PR;
                                  Serial.println("M5.BtnA Pressed");
                              } else {
                                  data->state = LV_INDEV_STATE_REL;
                          // Display flush function
                          void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p) {
                              uint32_t width = (area->x2 - area->x1 + 1);
                              uint32_t height = (area->y2 - area->y1 + 1);
                              M5.Display.startWrite();
                              M5.Display.setAddrWindow(area->x1, area->y1, width, height);
                              M5.Display.pushPixels((uint16_t *)&color_p->full, width * height, true);
                              M5.Display.endWrite();
                              lv_disp_flush_ready(disp);
                              auto cfg = M5.config();
                              M5Dial.begin(cfg, true, false);
                              Serial.begin(115200);
                              // LVGL initialization
                              lv_init();
                              lv_disp_draw_buf_init(&drawBuffer, buffer, NULL, SCREEN_WIDTH * SCREEN_HEIGHT / 10);
                              static lv_disp_drv_t disp_drv;
                              lv_disp_drv_init(&disp_drv);
                              disp_drv.hor_res = SCREEN_WIDTH;
                              disp_drv.ver_res = SCREEN_HEIGHT;
                              disp_drv.flush_cb = my_disp_flush;
                              disp_drv.draw_buf = &drawBuffer;
                              lv_disp_drv_register(&disp_drv);
                              static lv_indev_drv_t encoder_drv;
                              lv_indev_drv_init(&encoder_drv);
                              encoder_drv.type = LV_INDEV_TYPE_ENCODER;
                              encoder_drv.read_cb = encoder_read;
                              encoder_indev = lv_indev_drv_register(&encoder_drv);
                              // Create a group and assign it to the encoder input device
                              group = lv_group_create();
                              lv_indev_set_group(encoder_indev, group);
                              // Create focusable widgets
                              lv_obj_t *btn1 = lv_btn_create(lv_scr_act());
                              lv_obj_align(btn1, LV_ALIGN_CENTER, -60, 0);
                              lv_obj_t *label1 = lv_label_create(btn1);
                              lv_label_set_text(label1, "Button 1");
                              lv_obj_t *btn2 = lv_btn_create(lv_scr_act());
                              lv_obj_align(btn2, LV_ALIGN_CENTER, 60, 0);
                              lv_obj_t *label2 = lv_label_create(btn2);
                              lv_label_set_text(label2, "Button 2");
                              lv_obj_t *btn3 = lv_btn_create(lv_scr_act());
                              lv_obj_align(btn3, LV_ALIGN_CENTER, 0, 50);
                              lv_obj_t *label3 = lv_label_create(btn3);
                              lv_label_set_text(label3, "Button 3");
                              // Add widgets to the group
                              lv_group_add_obj(group, btn1);
                              lv_group_add_obj(group, btn2);
                              lv_group_add_obj(group, btn3);
                          • gordshG Offline
                            gordsh @gordsh
                            @gordsh thanks for sending, I actually don't know eez studio at all, I have never used it..
                              mukul_100_ @gordsh
                              @gordsh in your code, is the press function working successfully?
                              i am getting crashes for now, i am trying to use the button as a external button and not as a encoder button, the main problems seems to be init of button
                                SadE54 @gordsh
                                @gordsh Do you think with the lvgl m5dial setup , that Squareline Studio is usable ?
                                gordshG 1 Reply Last reply Reply Quote 0
                                • gordshG Offline
                                  gordsh @SadE54
                                  @SadE54 I believe it is.
