    calc software is not working
    1 Posts 1 Posters 840 Views
      JasonBeBrilliant
      i made this code,
      #include <Arduino.h>
      #include <M5StickCPlus.h>
      #include <math.h>
      // Define button pins (adjust if needed)
      #define BUTTON_A_PIN 35
      #define BUTTON_B_PIN 36
      // Calculator variables
      double operand1 = 0;
      double operand2 = 0;
      char operation = ' ';
      bool newNumber = true;
        M5.Lcd.setRotation(3); // Adjust rotation as needed
        M5.Lcd.fillScreen(BLACK);
        M5.Lcd.setTextColor(WHITE);
        M5.Lcd.setTextSize(2);
        pinMode(BUTTON_A_PIN, INPUT_PULLUP);
        pinMode(BUTTON_B_PIN, INPUT_PULLUP);
        displayScreen();
      void displayScreen() {
        M5.Lcd.fillRect(0, 0, 240, 135, BLACK); // Clear the screen
        M5.Lcd.setCursor(0, 0);
        M5.Lcd.print("Value: ");
        if (operation != ' ') {
          M5.Lcd.print(operand1);
          M5.Lcd.print(operation);
          M5.Lcd.print(operand2);
        } else {
      void calculate() {
        switch (operation) {
          case '+':
            operand1 = operand1 + operand2;
            break;
          case '-':
            operand1 = operand1 - operand2;
            break;
          case '*':
            operand1 = operand1 * operand2;
            break;
          case '/':
            if (operand2 == 0) {
              M5.Lcd.setCursor(0, 20);
              M5.Lcd.print("Division by 0!");
              delay(2000);
              operand1 = 0;
              operation = ' ';
              return;
            operand1 = operand1 / operand2;
            break;
          case 's': // Square Root
              operand1 = sqrt(operand1);
              break;
          case '^': // Power
              operand1 = pow(operand1, operand2);
              break;
          default:
            break;
        operation = ' ';
        operand2 = 0;
        newNumber = true;
        M5.update();
        if (M5.BtnA.wasPressed()) {
          if (newNumber) {
            operand1 = operand1 * 10 + 1;
          } else {
            operand2 = operand2 * 10 + 1;
          displayScreen();
        if (M5.BtnB.wasPressed()) {
            if (operation == ' ') {
              operation = '+';
              newNumber = false;
            } else if (operation == '+') {
              operation = '-';
              newNumber = false;
            else if (operation == '-') {
              operation = '*';
              newNumber = false;
            else if (operation == '*') {
              operation = '/';
              newNumber = false;
            else if (operation == '/'){
              operation = 's'; // Square Root
              newNumber = false;
            else if (operation == 's'){
              operation = '^'; // Power
              newNumber = false;
            else if (operation == '^') {
              calculate();
            displayScreen();
        if (M5.BtnC.wasPressed()){
          operand1=0;
          operand2=0;
          operation=' ';
          newNumber=true;
          displayScreen();
      but for some reason, it did not work at all. please help me.
