    CoreInk display fades
    12 Posts 3 Posters 7.1k Views
      ajb2k3 @desmbr
      @desmbr If you want data to remain visible after shutdown or sleep, you do as you have surmised have to trigger the Screen HV, write the data then shut down.
      The fading without the set screen HV is normal.
        desmbr
        Hi @ajb2k3 ,
        That is what I'm asking :) I don't see which widget/code can do so. Can you show an example please?
        Btw, what does HV stand for?
          desmbr @desmbr
          Sorry for bumping the topic, but I would really appreciate any kind of advice. I suppose missing Set screen HV block in UIFlow2.0 is a gap and is probably planned in a future release?
          Is there an equivalent in python code for that?
            felmue @desmbr
            Hello @desmbr
            I created an UIFlow2 light sleep example for M5CoreInk but I cannot confirm the display fading you are reporting.
            You can find my example in the UIFlow2 ProjectZone called: M5CoreInk_LightSleep_Test_UIFlow2.2.3
              desmbr @felmue
                desmbr
                There is something wrong with my device then.. This is what I see with your example project: 3db54d18-b216-4753-85ee-1759b5fb8fef-image.png
                  felmue @desmbr
                  Hello @desmbr
                  hmm, yes, that doesn't look good.
                  Have you tried without the hat connected?
                  Have you tried when running from battery?
                  Have you tried to fully power off / on M5CoreInk? E.g.
                  • disconnect USB-C
                  • press and hold RST button in the back for 5 seconds
                  • turn back on via side button (or by plugging in USB-C)
                  Also, are you running the latest UIFlow2 v2.2.3 firmware? Maybe use M5Burner to fully erase first and then reinstall UIFlow2 v2.2.3?
                    desmbr @felmue
                    Hi @felmue ,
                    I disconnected everything. Updated UiFlow to 2.2.3.
                    After complete reset I see Ui logo, then for a second I see startup menu and then screen blinks and everything disappears.
                      felmue @desmbr
                      Hello @desmbr
                      have you checked the boot option? In M5Burner click onto the Configure (yellow) button and then set Boot Option to Show startup menu and network setup. Then click onto Next to set the new boot option.
                        desmbr @felmue
                        @felmue said in CoreInk display fades:
                        Hello @desmbr
                        As I mentioned before, I tried that. The screen flashes a few times and then it is blank and I only see a vertical line on the right. If you look closer there are slightly whiter traces of UI
                        This is how it behaves: https://youtube.com/shorts/s7ljTruGtDk
                        And this is what remains: b44e18e6-eac2-4f64-8fbf-72d073483c06-image.png
                          felmue @desmbr
                          Hello @desmbr
                          indeed, that doesn't look good. I wonder if maybe the internal battery is defective preventing the power rails from reaching the proper voltages.
                          Edit: first, however I would unplug the hat and maybe try a different USB power supply.
                          If you still have warranty, I suggest you ask for a replacement.
                          If not, you might try to open it and disconnect the battery to see if that helps. These pictures I took a while ago might be helpful opening M5CoreInk.
