    4-20 mA Unit with wemos S2 mini ESP32
    17 Posts 3 Posters 9.2k Views
    • O Offline
      obstbauer
      it seems that I still have a problem....
      I have a current reading but the value is wrong,
      I get soemthing around 7.2 mA instead of 4 mA.
      I can measure the 4 mA with a multimeter in the circuit and the sensor should send 4 mA, so this is ok, but the M5Stack unit shows 7.2 mA and I don't understand why ? Any ideas ?
      My sensor is passive, I connected 24 V to the 4-20mA unit and all three jumpers are installed
      What is the meaning of the function "getCalCurrent" ? It is neessary for the current measurement ? It is necessary to set a "ref current" ?
      Thank you!
      • robskiR Offline
        robski @obstbauer
        @obstbauer try calibration function based on what you see with multimeter
        • O Offline
          obstbauer @robski
          @robski thanks for the answer
          so you mean if I measure with multimter 4.0 mA (which is true for the sensor) and the unit shows me 7.2 mA I should set the calibrated value to 4.0 ?
          Because this is not mentioned anywhere in a readme file or manual or in the description of the device, and it is not made in the example file at github
          but I am a beginner....
          • robskiR Offline
            robski @obstbauer
            @obstbauer thats what i did with mine initially, calibrate with known current value
            • O Offline
              obstbauer @robski
              @robski ok I think I found it:
              thank you I will try tomorrow
              • robskiR Offline
                robski @obstbauer
                @obstbauer yeah thats the registers table, I used Uiflow2 with calibration block but you are using not M5Stack controller I see
                • O Offline
                  obstbauer @robski
                  @robski what value do you take for "index" in the function
                  void MODULE_4_20MA::setCalCurrent(uint8_t index, uint16_t value)
                  • robskiR Offline
                    robski @obstbauer
                    @obstbauer haven't used index value
                    in uiflow2 ..ain4_20ma_0.set_cal_current(10) to set 10mA
                    ain4_20ma_0.set_cal_current(20) to set 20mA
                    • O Offline
                      obstbauer @robski
                      @robski yes maybe in uiflow2 but the function for the c program asks for an index and a value
                      • O Offline
                        obstbauer @obstbauer
                        I see really strange behaviour and I don't know the reason and I get no answers from the support.....
                        The example code from M5Stack say that the currentvalue should be divided by 100:
                        canvas.printf("Current:%.2fmA", (float)(meter.getCurrentValue(0)) / 100.0);
                        The values I get I have to divide by 10 to get the right current in mA.... and the other issue is that I can only use half of the measurement range, at 12.5 mA the ADC sends 65520...
                        maybe someone has an idea ?
                        • O Offline
                          change to a raspberry PI4 seems to be no solution too.....
                          it woud be nice if there would be a better documentation for people who want to use the units outside the m5stack universum....
                          • robskiR Offline
                            robski @obstbauer
                            @obstbauer this is uiflow example with raw value and float too
                            • O Offline
                              obstbauer
                              thank you, but I am still not able to read out or to set the cal current
                              M5Stack support doesn`t answer my mails... and it seems that there is nobody from the company around here, I think I will change to another board with better support
                              • robskiR Offline
                                robski @obstbauer
                                @obstbauer TBH if you are using M5Stack modules/units with not M5Stack controllers maybe its worth to have at least one M5Controller (atom?stick? )to be able to check module functionality
