    No RGB LED unit for UIFLOW 2.0?
    6 Posts 5 Posters 3.6k Views
      montanaman
      UIFLOW 1.x has a unit for the SK6812 LED strip called RGB LED but it seems to be missing from UIFLOW 2.0 -- or am I missing something?
      • Y Offline
        yuyun2000 @montanaman
        @montanaman Although the specific "RGB LED" unit for the SK6812 LED strip in UIFlow 1.x might not be directly available in UIFlow 2.0, UIFlow 2.0 still supports controlling SK6812 LEDs. There are several M5Stack units that integrate SK6812 LEDs and can be used in UIFlow 2.0, such as:
        Unit Key (SKU: U144): Embedded with one programmable RGB LED - SK6812, supports 256 level brightness.
        Unit Fader (SKU: U123): Comes with 14x SK6812 programmable RGB lights.
        Unit RGB LED Strip (SKU: A093): A programmable light strip using SK6812 LEDs, supporting digital addressing to control the color and brightness of each LED.
        Unit RGB LED (SKU: A035 A035 - B A035 - C A035 - D A035 - E): Another programmable light strip using SK6812 LEDs.
        Unit Encoder (SKU: U135): Equipped with 2x SK6812 programmable RGB LEDs.
        Unit HEX (SKU: A045): Has 37 SK6812 RGB LEDs.
        Unit ACSSR (SKU: U139): Features a programmable SK6812 RGB LED.
        Unit DCSSR (SKU: U140): Also comes with a programmable SK6812 RGB LED.
        You can use these units to achieve similar functionality in UIFlow 2.0.
        https://chat.m5stack.com/
          hacxx
          UIFLOW 2.0 has updated many units, and the SK6812 RGB LED support is now under the “Neopixel” or “Addressable LED” unit instead of “RGB LED.” Check for these new units in the device list. The functionality is similar but reorganized for better flexibility with different LED types. If you don’t see it, try updating UIFLOW to the latest version or check the official docs/forums for recent changes.
            montanaman @hacxx
            @hacxx Obviously I am missing something because UIFLOW 2.3.1 lists neither Neopixel nor Addressable LED in the unit list for me.
              random_dude
              Same here, I have multiple scrips and would like to build some ideas. Still waiting and hope for any added support with every new release.
              • felmueF Online
                felmue @random_dude
                Hi guys
                have you tried the RGB module in Hardware? Works fine for me.
                I created an example using an M5Atom to control 10 SK6812 RGB LEDs. You can find it in the UIFlow2 Project Zone: M5Atom_RGB_Test_UiFlow2.3.3
