    34 Posts 5 Posters 23.9k Views 1 Watching
    • robskiR Offline
      robski
      try below
        Kenzo @robski
        @robski Thanks for replying! With nothing connected to the Tube pressure sensor, I am getting a RAW value of 3,287 (12 bit option selected in the ADC parameter).
        In regards to a 3.6V reference, where is that in the documentation?
        I think we are getting close to solving this problem!
          Kenzo @Kenzo
          @robski - I stumbled across this youtube video about an Arduino Pressure Sensor and was thinking about testing a version of his method for coming up with a calculation...
          https://youtu.be/UrqPxwsPWGk?si=4Ho9CQwpoFZstMBk&t=321
          • robskiR Offline
            robski
            with your raw value as 3287
            sensor range -100 to 200
            analog range 0 to 4095
            your calculated pressure should be around 140
              Kenzo @robski
              @robski - hmmm.... Well that raw value was with nothing connected to the Tube Pressor sensor. Because nothing is connected to the tube pressure sensor I would assume it would be closer to 0 Kpa... 140Kpa is a big difference from 0 Kpa... I wonder what we are missing?
                Kenzo @robski
                @robski I keep coming up with 140Kpa also...
                We must be missing something...
                • robskiR Offline
                  robski
                  just connect voltage to sensor and measure what voltage it is giving out between output pin and ground. for 0 kPa your raw Analog value should be around 1300 i think
                  K 2 Replies Last reply Reply Quote 1
                    Kenzo @robski
                    @robski - I think you hit on something there! I measured the voltage between the ground and the sensor and it came to around 1.1v which according to the graph should be around 0 Kpa. (see attached photos) Something is definitely strange...
                      Kenzo @Kenzo
                        Kenzo @Kenzo
                        Also here is the formula I was using to calculate Kpa
                        So for 12 bit parameter, this gives a kpa resolution of 300Kpa/4096 bits or 0.0732421875 kpa/bit (73.2pa/bit)
                        x = ( (0.0732421875 kpa/bit * Raw Value bit) - 100Kpa)
                        x = ( (0.0732421875 kpa/bit * 3287 bit) - 100Kpa) = 140.7Kpa
                        For the 16 bit parameter this gives a kpa resolution of 300Kpa/65536 bits or 0.00457763671875 kpa/bit (4.6pa/bit)
                        x = ( (0.00457763671875 kpa/bit * Raw Value bit) - 100Kpa)
                        x = ( (0.00457763671875 kpa/bit * 52600 bit) - 100Kpa) = 140.8Kpa
                          Kenzo @robski
                          @robski I sent an email to M5Stack Support about the possible issue with the Tab5 and Tube Pressure sensor BUT no response so far....
                          • kurikoK Offline
                            kuriko @Kenzo
                            @Kenzo
                            This is an ADC problem. We are fixing UiFlow2 codes. Please be patient.
                              Kenzo @kuriko
                              @kuriko Thanks Kuriko for responding and taking a further look into the issue! Looking forward to testing out the updated version of UiFlow with the fix!
                              I will now wait quietly and patiently while your team works on an ADC fix.
                                Kenzo @kuriko
                                @kuriko Just finished testing the latest release of UiFlow (v2.3.2 ).
                                The Kpa readings was better this time but the accuracy is not there yet... See attached photo.
                                Hopefully the next release will improve the accuracy of the Tube/Air sensor and Tab5...
                                  Kenzo @Kenzo
                                  Just tested another release of UiFlow (version 2.3.3) for the Tab5... Unfortunately, I am seeing the same results that I saw with Version 2.3.2... -16Kpa without any air tubes connected to the M5Stack Air Tube sensor... Along with the i2c driver install error...
                                  Hopefully M5Stack Team is getting close to resolving the issue... I was planning to use the Tab5 project I was working on for the M5stack Innovation contest but it looks like that will not happen due to the issues I am running into with finding an air tube sensor that will accurately work with the Tab5... Oh well... Hopefully the M5stack team will release an upgraded Air Tube sensor soon that will easily work with the Tab5... Until then, I will keep searching for a solution....
