    34 Posts 5 Posters 23.9k Views 1 Watching
      Kenzo @robski
      @robski I keep coming up with 140Kpa also...
      We must be missing something...
      • robskiR Offline
        robski
        just connect voltage to sensor and measure what voltage it is giving out between output pin and ground. for 0 kPa your raw Analog value should be around 1300 i think
        K 2 Replies Last reply Reply Quote 1
          Kenzo @robski
          @robski - I think you hit on something there! I measured the voltage between the ground and the sensor and it came to around 1.1v which according to the graph should be around 0 Kpa. (see attached photos) Something is definitely strange...
            Kenzo @Kenzo
              Kenzo @Kenzo
              Also here is the formula I was using to calculate Kpa
              So for 12 bit parameter, this gives a kpa resolution of 300Kpa/4096 bits or 0.0732421875 kpa/bit (73.2pa/bit)
              x = ( (0.0732421875 kpa/bit * Raw Value bit) - 100Kpa)
              x = ( (0.0732421875 kpa/bit * 3287 bit) - 100Kpa) = 140.7Kpa
              For the 16 bit parameter this gives a kpa resolution of 300Kpa/65536 bits or 0.00457763671875 kpa/bit (4.6pa/bit)
              x = ( (0.00457763671875 kpa/bit * Raw Value bit) - 100Kpa)
              x = ( (0.00457763671875 kpa/bit * 52600 bit) - 100Kpa) = 140.8Kpa
                Kenzo @robski
                @robski I sent an email to M5Stack Support about the possible issue with the Tab5 and Tube Pressure sensor BUT no response so far....
                • kurikoK Offline
                  kuriko @Kenzo
                  @Kenzo
                  This is an ADC problem. We are fixing UiFlow2 codes. Please be patient.
                    Kenzo @kuriko
                    @kuriko Thanks Kuriko for responding and taking a further look into the issue! Looking forward to testing out the updated version of UiFlow with the fix!
                    I will now wait quietly and patiently while your team works on an ADC fix.
                      Kenzo @kuriko
                      @kuriko Just finished testing the latest release of UiFlow (v2.3.2 ).
                      The Kpa readings was better this time but the accuracy is not there yet... See attached photo.
                      Hopefully the next release will improve the accuracy of the Tube/Air sensor and Tab5...
                        Kenzo @Kenzo
                        Just tested another release of UiFlow (version 2.3.3) for the Tab5... Unfortunately, I am seeing the same results that I saw with Version 2.3.2... -16Kpa without any air tubes connected to the M5Stack Air Tube sensor... Along with the i2c driver install error...
                        Hopefully M5Stack Team is getting close to resolving the issue... I was planning to use the Tab5 project I was working on for the M5stack Innovation contest but it looks like that will not happen due to the issues I am running into with finding an air tube sensor that will accurately work with the Tab5... Oh well... Hopefully the M5stack team will release an upgraded Air Tube sensor soon that will easily work with the Tab5... Until then, I will keep searching for a solution....
