    Desperately Seriously Need Help Programming/Coding!!!!
    4 Posts 3 Posters 1.1k Views
      SparklesForever
      Can someone please PLEASE help tell me what to do with UiFlow 2.0 using a yellow M5 little block sensor thing?? This stuff is like a language from another planet for me and this post is my last resort to figure out how to program/code it for the below:
      Write a program that will:
      a. Read the soil moisture sensor value from the watering unit.
      b. Compare the value to a defined threshold (30,000 should do nicely).
      Also..
      Change the LCD color if the value falls below the threshold.
      THANK YOU EVERYONE THAT CAN HELP IN A DESPERATE SITUATION!!!!!!!!!!
      • robskiR Offline
        robski
        for start: what hardware do you have for this task, are you able to update firmware via M5Burner to your controller?
        • kurikoK Online
          kuriko @SparklesForever
          @SparklesForever
          what is "yellow M5 little block sensor" specified?
          • robskiR Offline
            robski
            did you looked here by chance?
            M5 watering unit
