    Tab5 display issue
    12 Posts 5 Posters 6.5k Views 1 Watching
    • O Offline
      oroppas @kuriko
      @kuriko
      @kuriko said in Tab5 display issue:
      In other words, did you do anything special before this problem occurred?
      No, I did not do anything special.
      Did the problem develop gradually or suddenly?
      It happened all the sudden.
      Does the screen behave the same way when you flash other firmware?
      I haven't tried that yet. I need to look up how to do that.
      • O Offline
        oroppas @oroppas
        One thing I noticed was that while powered through USB-C port, the Tab5 gets really hot, especially around the USB-C port on the display side.
          scroggyg @oroppas
          I would definitely a hardware problem, probably due to the connection to the display.
          Also on the point of heat, the TAB5 seems to draw nearly almost 3 Watts, probably mostly on the larger display back light. I have had great problems powering it because of this. at 12 Volts on the HVIN it draws up to 240mA.
          • O Offline
            oroppas @scroggyg
            @scroggyg
            Yeah, I agree with you. It looks like the durability issue...
              sapphire
              This is the second time I've seen this hardware problem. The first time is not on a Tab5 but on another brand. I assume you also have a pulsation problem.
              • kurikoK Offline
                kuriko
                @oroppas
                Please contact support@m5stack.com
                • O Offline
                  oroppas @kuriko
                  @kuriko
                  I contacted the reseller. They said they'd contact m5stack.
                    karuna
                    Yes, it is the display's problem. Its flex cable might be damaged.
                    • S sapphire referenced this topic on
                    • O Offline
                      oroppas @karuna
                      The reseller sent me a new one and it's working. I send them back the defective one so that they can investigate and improve the quality and durability.
                        sapphire @oroppas
                        @oroppas good news
