I have a TAB5 and a M5STAMP-CatM module, there doesn't seem to be any way to connect the 2 The Stamp fits in the aperture in the case and there are pads on the TAB5 PCB but no pins. So do they connect?
Best posts made by scroggyg
TAB5 and Stamp Connector
Latest posts made by scroggyg
RE: esp32/rom/rtc.h No such file or directory
@scroggyg The file exists, could the path length be too long?
C:\Users\xxxxxxxxxxxxxx\xxxxxxxxxxxxxx\Documents\Arduino\hardware\espressif\esp32\tools\sdk\esp32s3\include\esp_rom\include\esp32\rom -
I am trying to build the 6060_Push.ino in Arduino IDE 2.3.6.
I have added the additional boards
and
and the STamPLC libraries
Yet it can't find rtc.hWhat else do I need to load?
Thanks -
RE: Using 6060 Push
@scroggyg Neither the 6060 push or the STAMP PLC are provided with connectors. The connector type seems to be ht-3.96 4p which I can only find by importing from China. I have some PowerCAN modules which were supplied with this connector, could you please provide these connectors in future?
RE: Using 6060 Push
I see from the code the ID is stored in EEPROM, but I suspect there can only one device on the bus at a time when the address is set.
Also I suspect I would use an address other than 1, as this is the default address, set when a new device is added -
Using 6060 Push
Can I connect multiple 6060 push on the same RS485 bus. I see that we can set a device ID, is this stored on the device after a power cycle?
M5Tab Running out of memory error
I am writing an Python application for the M5 TAB5, which was running well but I am now getting memory errors
I am not using any networking in the application. before upgrading 2.3.6 Hotfix 2 it was fine
RE: TAB5 python Crash
@scroggyg I rewired the board to Port A and the code works. There seems to be an issue connecting an I2C device on the ExtPort2, the python crashes when the Extio2 is connected. That is all I have tested, there may be other issues.
@scroggyg Felix, I ran your code, but changed to the internal I2C G31 & G32 the bus I am running the M0 from and it crashes.
I have made a board using the M0 from the EXtio2, I am using this successfully with other TAB5s -
Thanks Felix, I updated the TAB5 to V2.3.6-hotfix2 but the problem remains. As a trest I write once a second and that works, when I then call it in another function it panics
This code panics
This code works
Any help would be appreciated -
TAB5 python Crash
I was trying to write an output on EXTIo2 and I got a python crash and a dump.
I then tried to update the TAB5 to V2.3.6-hotfix2.
The device programmed and the default UIFlow screen is showing, but now I cannot program the device.
I reverted to 2.3.5 and I can program the TAB5
