    No files ever work with the Speaker
    2 Posts 1 Posters 853 Views
      michael.koppelman
      I've loaded a small, mono, 16-bit, 44.1kHz audio file into flash in UFlow 2.0. It plays fine within UFlow. No matter what I do, I get an ENOENT error trying to read the file.
      File "<stdin>", line 26, in <module>
      File "<stdin>", line 18, in loop
      OSError: [Errno 2] ENOENT
      a snippet of the code from the Python side of things:
      def setup():
        global rgb
        M5.begin()
        Widgets.setRotation(1)
        Widgets.fillScreen(0x222222)
        rgb = RGB()
        Speaker.begin()
        Speaker.setVolumePercentage(0.5)
      def loop():
        global rgb
        M5.update()
        Speaker.playWavFile('/flash/res/audio/test1.wav')
        if Speaker.isPlaying():
          rgb.fill_color(0xffffff)
        time.sleep(2)
      No code I've downloaded from other people works either! I can play tones out of the speaker, I can read images out of flash. I cannot read audio files out of flash.
        michael.koppelman
        This is because UIFlow2.0 sucks with the M5Go. Almost no hardware works. I would abandon all the silly BS and go right to PlatformIO if you want to avoid pulling your hair out.
        This ecosystem is so convoluted. I thought I might buy these for presents for kids. No way. Your average parent could not make this shit work ever.
