M5Unified FreeRTOS (ESP-IDF) Application not Compiling
I am attempting to create a new ESP-IDF application that will use FreeRTOS application (so not Arduino). I am getting build errors and I was wondering if anyone has managed to get this working.
So I did the following:
idf.py create-project M5Test idf.py set-target esp32p4 idf.py add-dependency "m5stack/m5unified^0.1.16" idf.py buildI see the managed components (M5Unifed and M5GFX) caaded to the
managed_componentsdirectory as expected.However I see build errors in the M5GFX component.
ESP-IDF: 5.5
Target platform: Tab5Thanks in advance,
Mark -
I finally managed to get an application working with graphics and touch on the Tab5. My solution:
- Removed any reference to managed components in the
idf_component.ymlfiles. - Clone the
M5UnifiedandM5GFXrepositories and put them in thecomponentsdirectory. - Added references to
CMakeLists.txtfor the added components.
Application now builds and I have tested the display with the
BarGraphanf theTouchTestapplications.Hope this helps anyone experiencing the same issue.
Regards,
Mark - Removed any reference to managed components in the
